bigger tires
Old Dec 30, 2009 | 05:37 PM
dakota02guy's Avatar
dakota02guy
Default bigger tires
im an idiot when it comes to the tire sizes on my truck. so i was wondering, that is the size id have to go to keep my stock rims/wheels and go to about 31-33in tires? THANKS!
the tires i have on now are p255/65r16
Old Dec 30, 2009 | 06:14 PM
DuckandDodge's Avatar
DuckandDodge
you can go up to 31 with maybe minor rubbing. 30 will fit fine, id get the 30s if i were you, since you have 2wd i assume your not going through the thickest of the off roading and such. 30s will weigh slightly less than 31s saving u a bit of gas, besides they are cheaper and most tire companies start with their A/T, M/T, etc line tires at that size. also a lot of tire shops will only guarantee a fit and warranty on tires one size up from stock. btw stock for 2wd is 29.
hope that helps
Old Dec 30, 2009 | 07:06 PM
batman13's Avatar
batman13
My 2wd came stock with 31x10.5s, no rub fit fine
Old Dec 30, 2009 | 07:53 PM
95_318SLT's Avatar
95_318SLT
I can't promise that all of these sizes exist, or that all of them will fit, but...
275 70 16 = 31.16 x 10.83
285 70 16 = 31.71 x 11.22
295 70 16 = 32.26 x 11.61
305 70 16 = 32.81 x 12.01
255 75 16 = 31.06 x 10.04
265 75 16 = 31.65 x 10.43
275 75 16 = 32.24 x 10.83
285 75 16 = 32.83 x 11.22
Old Dec 30, 2009 | 07:57 PM
batman13's Avatar
batman13
*Changing the tire height will adversely affect the speedometer and we are not responsible for any speeding tickets that my be acquired do to non-calibrated speedometers and the use of larger than factory tires
Old Dec 31, 2009 | 03:13 AM
dakota02guy
hope that helps
i have 2inch spring spacers on the front end so 32-33 might work?
Old Dec 31, 2009 | 09:46 AM
DuckandDodge
i wouldnt push for 33s i have a friend with a 03 qc 3.9 2/4 with a 2in spacer and she could only get 32's and they rub when she turns a bit. but not when she goes over bumps and such.
Old Dec 31, 2009 | 10:01 AM
batman13's Avatar
batman13
you can go 33s with a little bit of trimming.
32s with less trimming
Old Jan 7, 2010 | 09:08 PM
dakota02guy
sick! thanks guys!
