Humming while accelerating
Old Jan 11, 2010 | 07:29 PM
01dakv686's Avatar
01dakv686
Default Humming while accelerating
Like the title says, my trucks makes a humming noise while on the gas. It stops when i let off. What could it be?
Old Jan 11, 2010 | 07:40 PM
thunder98110's Avatar
thunder98110
we will need more info. tranny noise? engine?......
Old Jan 11, 2010 | 08:01 PM
95_318SLT's Avatar
95_318SLT
I don't know what you mean by a humming noise, but if its a whine it could be the pinion bearings going bad. But like thunder98110 said, we need more info!
Old Jan 11, 2010 | 10:05 PM
dodgeramguy85's Avatar
dodgeramguy85
Also could be your cv shaft
Old Jan 11, 2010 | 10:52 PM
somebodynowhere's Avatar
somebodynowhere
my truck hums when i play blue grass music
Old Jan 15, 2010 | 04:17 PM
01dakv686's Avatar
01dakv686
I'm not sure where the noise is coming from. But it's only when on the gas. I just put in a rear end with only 56k on it. Its a 9.25 12 bolt with limited slip. The truck made the noise before i changed the rear end.
The truck is an 01 3.9 Auto
Old Jan 15, 2010 | 05:57 PM
deranged's Avatar
deranged
Typical Dodge. It's happiest when you're on the gas!
Old Jan 21, 2010 | 08:37 PM
metalsrfr's Avatar
metalsrfr
couldnt agree more !
also check u joints make sure they are well greased a buddy had that problem ended up being u joints .
Old Feb 24, 2010 | 04:51 PM
miniyog's Avatar
miniyog
Default me too
i have the same prob with my 01 dakota 4.7 only makes the whine/hum when giving gas also happens when slowing down. when im coasting it doese nothing pich changes with speed thou please help
Old Feb 25, 2010 | 11:12 PM
Blaze10's Avatar
Blaze10
Wheelbearing, cv axle, ball joints, i heard the same noise and checked them all and they all were bad. if you turn left or right and it sounds like your rubbing it's definitly your wheelbearing
