changed oil filter fixed oil pressure dropoff!
Old Jan 20, 2010 | 07:45 PM
dazeofmylife's Avatar
dazeofmylife
Default changed oil filter fixed oil pressure dropoff!
Greetings Dodge Dakota Gang members,
My 1997 5.2 litre Dakota Sport was having the oil pressure gauge drop to zero after warmed up at a red light. I had a FRAM filter on it.
I purchased a WIX $6.00 oil filter, put it on, and the problem was solved...the oil pressure doesn't drop at red lights anymore.
Old Jan 21, 2010 | 08:45 AM
bpark8824's Avatar
bpark8824
The Fram has bigger openings in the filter. There for its more "free flowing" I guess you could say, which leads to low oil pressure when at idle. The WIX filters are supposed to be good, my father used to always use them. So it probably actually filters better which in turn leads to a little more oil pressure.
Old Jan 21, 2010 | 12:00 PM
dodgeramguy85's Avatar
dodgeramguy85
I use the mopar filters still notice a drop in oil pressure when sitting but is fine in summer time.
Old Jan 21, 2010 | 03:42 PM
Brutus's Avatar
Brutus
I think Purolater makes the Mopar and Motorcraft filters. Wix makes Napa. And Fram I feel is not good at all.
Old Jan 21, 2010 | 03:49 PM
bpark8824's Avatar
bpark8824
Thats because Fram makes some of the Mopar filters. So you may actually have a Fram filter.
And to Brutus, there are a couple different companies that make the Mopar filters. I think Fram is one and Purolator is another. I forget what the 3rd one is...
Old Jan 21, 2010 | 04:30 PM
dodgeramguy85
Oh well I still use fram on everything else anyway.
Old Jan 21, 2010 | 04:39 PM
varsis's Avatar
varsis
I use the napa filters same price as the fram ones, and they are a lot better.
Old Jan 21, 2010 | 09:35 PM
bpark8824's Avatar
bpark8824
Yeah Napa filters are supposed to be good filters. They're made by WIX who make good filters.
Old Jan 22, 2010 | 09:11 PM
Propwash's Avatar
Propwash
I believe the oil pressure sending unit is downstream of the filter, and therefore the filter should make no difference at all.
I use a Napa Gold filter, and the pressure falls at idle, which it should anyways.
Old Jan 22, 2010 | 09:24 PM
thunder98110's Avatar
thunder98110
heres an interesting link. this guy gives you an overview of different brands of oil filters. he also takes them apart and shows you whats inside.
http://www.youtube.com/watch?v=6BQha...eature=related
