View Poll Results: What do you think about the new Hemi motors.
They're Junk.
0
0%
Better than the old ones.
12.50%
I like the old one's better.
12.50%
The best Dodge Motor available today.
50.00%
Other Dodge Motors are just as reliable.
0
0%
Can't decide.
25.00%
Voters: 8. You may not vote on this poll
Dakota Hemi Swap!! With pics!!!
Old Feb 8, 2014 | 01:59 PM
  #151
cooper1340s's Avatar
cooper1340s
Would it be possible to put a Hemi in a 1998 Dakota Sport 4X4?
Old Feb 8, 2014 | 02:04 PM
  #152
cooper1340s
Does the year of the Dakota matter for a Hemi swap? Would it be possible to put a Hemi in a 1998 Dakota Sport 4X4?
Old Feb 10, 2014 | 08:30 AM
  #153
HemiDak-Quad's Avatar
HemiDak-Quad
Anythings possible .. The best swap to do is a 4.7-to 5.7 . The motor and trans. bolt together and the computers are close.. I have a 1995 Jeep Wrangler I would LOVE TO PUT A Hemi in , but I would probably have to swap to carb. and distributor .. That would cost too much..
Old Feb 10, 2014 | 03:13 PM
  #154
project-hemi's Avatar
project-hemi
hemidak I have been following this thread for quite a while now doing my swap to a 2001 4x4 Dakota. ive got the engine in and driving but I cant get the transmission to shift out. I have a 5.7 from a 2003 ram that I dropped in. my question is do I need the tcm to make it shift out?
Old Feb 11, 2014 | 04:32 PM
  #155
HemiDak-Quad
Default 03- tcm swap
Did you get the ecm from the Ram donor truck ? If so it should be a single box instead of a split "ecm"-"tcm" like the 2001 came with. That's the one you should use.. I would get a 2004 if possible they're easier to tune and manage . Also , did you use the trans from the Dak- or the Hemi trans ? I need more info to be sure of the problem ..
Old Feb 11, 2014 | 07:55 PM
  #156
mopar_noob04's Avatar
mopar_noob04
New Member
[QUOTE=HemiDak-Quad;3131826] thanks my head gasket blew in my dakota im about to start my build any thoughts on a sas swap for the dakota?
Old Feb 11, 2014 | 09:24 PM
  #157
project-hemi
Yes I got the ecm from the donor truck. I used the transmission that was in the dakota. Im thinking that I have a wire or 2 maybe wrong. Not sure though.
Old Feb 12, 2014 | 07:34 AM
  #158
DDIRI's Avatar
DDIRI
I have a tcm and an ecm from an 03 if you need either shoot me a PM.
Old Feb 12, 2014 | 06:24 PM
  #159
HemiDak-Quad
Did you get the complete wiring harness from the Hemi ? It should have came with some transmission plugs , make sure you have them all plugged in tight and no clipped wires..The Dak. Harness won't work .. Also check the harness coming from the cab. behind the left wheel.. If you have wires cut look the colors up on my thread and find out where they go...
Old Feb 12, 2014 | 10:16 PM
  #160
project-hemi
Ok I think I know where the problem is now.. thanks for your help. Ill post back and let you know
