2000 Dakota Club Cab SLT Brake lights will not turn off
Old Jan 25, 2010 | 05:27 PM
Nick8216's Avatar
Nick8216
Default 2000 Dakota Club Cab SLT Brake lights will not turn off
Ok I will try to make this short and simple. A few days ago I shut my car off, turned off lights and noticed my exterior brake lights and cab light were not off. I did make sure everything was turned off, also kept pumping and lifting on brake pedal. So then I disconnected the battery. Today I reconnected the battery and lights are still on.
Any ideas I don't wanna have to get screwed by a mechanic.
Coincidentally while it rained one of my fog lights collected some water in the lamp and I did use my lights. Could this have something to do with it?
Old Jan 25, 2010 | 05:52 PM
tamcnally's Avatar
tamcnally
From: Salisbury, Vermont (home) - Lima, Ohio (school)
well if your brake lights wont turn off, that can only mean you have a short to power somewhere. do you have a trailer light plug in? you could have a problem there. i dont think the fog lights would have anything to do with it.
Old Jan 25, 2010 | 08:47 PM
01SilverCC's Avatar
01SilverCC
I doubt the rain in the fog lights caused the problem. More likely the brake light switch is bad. A new one should not cost too much. I'd replace the switch first, unless there are more obvious problems, maybe with trailer wiring like Tmcnally said.
Jimmy
Old Feb 9, 2010 | 07:03 PM
Nick8216's Avatar
Nick8216
thanks for all the help guys, I actually just pulled out the brake light fuse, dusted it off and the lights were off when i placed the fuse back in. Works fine now, I don't know if it solved the whole problem or what ha ha. but it works!
