LED Lightbar
Old Feb 14, 2010 | 03:50 PM
portman51's Avatar
portman51
Default LED Lightbar
I have 99 Dakota and was wondering if anyone else has been able to put in a LED light under the tailgate and above the bumper. it seems to me that there is not much room for anything to be seen.
Thanks
Old Feb 14, 2010 | 08:40 PM
HandedDown98's Avatar
HandedDown98
i've tried and the light sticks out to far and you wont be able to put the tailgate down. You could put it up higher but i think it looks trashy. I took mine back and said the turn signals didnt work
Old Feb 15, 2010 | 04:41 PM
6x6TRex's Avatar
6x6TRex
Thumbs down
I have a 04 Dakota and the tailgate sticks below the top of the bumper, so couldn't mount it there. I had mine mounted 2 ways before the bar died and I removed it.
1st - I removed all of the self-adhesive pads, flipped the bar upside down, and screwed it to the stock plastic bedliner on the tailgate.
2nd - After I had a tonneau cover installed, I made a piece of angle iron that I bolted to a channel in the tonneau cover. I then bolted the bar to the angle iron.
1st way worked ok, had to be careful to make sure I didn't rip the bar off. 2nd way worked great, would still have it if the bar hadn't died.
Old Feb 16, 2010 | 05:57 PM
portman51's Avatar
portman51
So was that then mounted on the top of the tailgate? I also have a tonneau cover installed. Do have any pics of this installed?
Thanks for all the help
Old Feb 18, 2010 | 11:57 AM
6x6TRex's Avatar
6x6TRex
I don't have any pictures of it installed, but I'll take some pictures of the mount and bar this weekend. Here's a paint drawing of how I had it mounted.
Black is the cover, red is the angle iron, blue is the bar, green is the tailgate, and gray is bolts.
Old Feb 18, 2010 | 01:01 PM
portman51's Avatar
portman51
alright thanks alot, a little different then what i would think to do, being above the tailgate but if it works that would be sweet.
Old Feb 18, 2010 | 06:05 PM
usmrocks's Avatar
usmrocks
http://www.sspmustang.org/images/Pin...akota_rear.JPG
