can i remove my clutch fan
Old Feb 21, 2010 | 05:02 AM
macx's Avatar
macx
Sure can -
http://www.mediafire.com/?sharekey=1...cd73fa11fc5db1
Have run this for over 2 years and absolutely love it.
The variable speed soft start control works like a charm.
I also use a relay with it for safety sake.
I've read the "new" hot setup is the Chevy HHR fan available at
Rock Auto for very reasonable.
Old Feb 22, 2010 | 06:59 PM
chickenlights's Avatar
chickenlights
is supose i could just reverse the polarity of the wires and make it a push fan. i don't understand why they would put a puller fan on the front. that doesn't make any sense. GOOD JOB AGAIN DODGE!!
Old Feb 22, 2010 | 08:06 PM
00dakSport's Avatar
00dakSport
the problem is the stock fan is low output.
it's on the engine side of the radiator.
making it a push fan won't help.
Old Feb 23, 2010 | 07:45 AM
bpark8824's Avatar
bpark8824
Originally Posted by Josh Abels
The 4.7 already comes with an efan stock so would he have to upgrade it to a better one
You have an e fan not a clutch fan???
Old Feb 23, 2010 | 09:01 AM
Josh Abels's Avatar
Josh Abels
My truck came with the Efan and clutch fan stock it may have been an option
Old Feb 23, 2010 | 09:42 AM
thunder98110's Avatar
thunder98110
same here
Old Feb 23, 2010 | 01:25 PM
parky07's Avatar
parky07
same hear, I have a small elec. fan along with the clutch fan. But my clutch fan is starting to go, so im switching to elec. in the spring. The plan is a 16" fan with a controller, I just cant decide whether to go a manual control, or a thermomostat control
Old Feb 23, 2010 | 02:46 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
all 4.7s came with a clutch fan and an e-fan from the factory, the efan goes on with the AC and when the temp gets above (i THINK) 210, so the efan is not used under normal conditions
Old Feb 23, 2010 | 04:03 PM
00dakSport's Avatar
00dakSport
sounds like the stock efan never even gets used.
has anyone put a switch on theirs?
...or have it go on at 185*
Old Feb 23, 2010 | 06:22 PM
Me&MyMopar's Avatar
Me&MyMopar
my truck also has the efan along with the clutch fan, but I don't trust using that fan on it's own. As I said earlier, I've removed the clutch fan for now, but I intend to ad the taurus efan to replace it. I removed it, because the truck has been running cold this year, to the point that it's affecting the heater output. I can leave it sit idle in the garage with out the clutch fan attached, and it doesn't even begin to overheat. I believe that the factory efan is for the A/C, because the only time I hear it running, is when the A/C is turned on.
