HELP! TIMING CHAIN PROB!
Old Apr 27, 2005 | 02:04 AM
dodgeman4x4's Avatar
dodgeman4x4
Default HELP! TIMING CHAIN PROB!
ok, just bought my 97 dak, but needs new timing chain. it didn't have a lot of oil on it. It was wet and all, but not soaked. The mechanics thought it should have tons more! is that so or do i have low oil pressure. How would i tell if i have low oil pressure, i mean where is the needle on the gauge supposed to be at? HELP ME WITH MY NEW TRUCK PLEASE!!!
Old Jan 22, 2007 | 11:31 AM
Erich_121's Avatar
Erich_121
Default RE: HELP! TIMING CHAIN PROB!
At idle if your truck sounds like its rattling, sorta like a can of marbles, then you need a new timing chain. The timing chain case itself should be getting oil regularly. If its dry then you might have a problem with your oil pump, if its got oil on it i wouldnt worry about it. You should have oil pressure between 40 and 60 psi. I know that on mine my pressure goes up when i rev the truck, but thats normal. Just make sure its never below 40psi.
Old Jan 22, 2007 | 02:56 PM
steve05ram360's Avatar
steve05ram360
when I did mine on the 2000 ram I dont recall there being alot of oil on it either... one suggestion though is to get a good double roller set to replace it. stock ones suck.
[IMG]local://upfiles/1508/AE5DC83B262E41D38FB2EFAE7FFD8EDC.jpg[/IMG]
[IMG]local://upfiles/1508/5164B017AEBA4A8C9FF6BBEFB008C9FA.jpg[/IMG]
Old Jan 22, 2007 | 03:18 PM
Erich_121's Avatar
Erich_121
What special tools would you need for that job?
Old Jan 22, 2007 | 03:23 PM
steve05ram360
depending on the year, you will need 1 of 2 different crank pulley/harmonic balancer pullers... if the pulley is part of the balancer then you need this one... if not then there is a STD puller you can get. rent them from autozone and they will be free. pay for the tool, then they refund your cost when you return it.
[IMG]local://upfiles/1508/0BDE109EBF724712944B9A2F1D6A8D3F.jpg[/IMG]
