Cat question
Old Mar 18, 2010 | 07:27 PM
carp1's Avatar
carp1
Default Cat question
Hello, I have a 2001 quad cab 4x4 with the 4.7 and an auto. My cat pipe on the drivers side is leaking and needs replaced. My question is can I eliminate the cats on each bank, and just run through just one main one? Will it trip a code? I will be using all the o2 sensors. Rock auto sells one that is direct fit with only one cat. Thanks for the help.
Chad
Old Mar 18, 2010 | 07:49 PM
00dakSport's Avatar
00dakSport
if ur talkin bout the two smaller cats you need those for air/fuel mixture.
bad for enigine
i think people on here have taken the bigger one off but not sure.
Old Mar 18, 2010 | 09:23 PM
CSCustomCars's Avatar
CSCustomCars
How many 02 Sensors do you have?
If you have one on each side before the small cats, and then one after the larger cat, then yes, you can run a single cat.
If you have one on each side before the small cats and one on each side after the small cats, then no, you can not use the one single cat.
The cats are not used to monitor Air/Fuel, the 02 sensors before the cats are. The o2 sensors after the cat monitor catalytic efficiency.
Having the two smaller cats, and one larger one you probably have California emissions. If you live in CA, then you MUST have both the small cats and the large cat.
Old Mar 18, 2010 | 11:15 PM
carp1's Avatar
carp1
Thanks for the info. I will look tomorrow to see haw many o2s I have. I live in PA, but I have emissions that use the obd2 plug, so I can't have any codes.
Thanks again.
Chad
Old Mar 19, 2010 | 04:18 PM
CSCustomCars
OBDII is used on all vehicles made after 1996, Cali emissions or not. The only way I know of to tell if you Cali emissions is how many o2's you have.
Old Mar 20, 2010 | 09:40 AM
carp1's Avatar
carp1
Thanks for the help. I looked yesterday, and found out I have an O2 sensor on both sides of the precats. I called the local exaust shop, and they are going to look at it. They said they probably could fix it instead of replacing all three cats. Hopefully it will be cheaper.
Thanks Chad
