My "new" exhaust is complete
Old Mar 25, 2010 | 12:10 PM
Josh Abels's Avatar
Josh Abels
I prolly wouldn't do that don't think u want ur exhaust shooting straight at ur rear end with all the brake lines and stuff there
Old Mar 25, 2010 | 12:13 PM
thunder98110's Avatar
thunder98110
good call.
Old Mar 25, 2010 | 12:26 PM
Josh Abels's Avatar
Josh Abels
have u tried to pull ur tailpipes outa ur muffler yet? mine was all just clamped together so i coulda pulled it out if i worked at it more but it wouldn't come out till i had the system off
Old Mar 25, 2010 | 12:28 PM
thunder98110
mine is all welded
Old Mar 25, 2010 | 12:29 PM
Josh Abels's Avatar
Josh Abels
ahhh that throws a wrench in everything then, see i got the advantage of being able to change mine when ever i want lol
Old Mar 25, 2010 | 01:13 PM
thunder98110
i went out and took at look, if i cut it right after the muffler i will have like 2 feet distance from the exhaust to any brake lines.....think that would cause any issues?
Old Mar 25, 2010 | 01:16 PM
Josh Abels's Avatar
Josh Abels
thats about what mine is, i personally wouldn't do it cause you will have a lot of heat comin out
do what i did and order a 180 degree bend and make a couple of turn downs just to be safe
Old Mar 25, 2010 | 02:22 PM
alleymad99SLT's Avatar
alleymad99SLT
Put your hands two feet from your exhaust pipe. Hold them there. How long before it gets hot?????
I am guessing that since there is no way your exhaust is gonna burn your hands from 2 feet away, it won't affect other things that are two feet away either.
