removing Cat in 1998 v6 worth it ?
Old Mar 29, 2010 | 03:45 PM
wheeler_02's Avatar
wheeler_02
Default removing Cat in 1998 v6 worth it ?
Hey Guys i have a 98 V6 with a flow master dual exhaust already on it i am thinking of removing the cat and replacing it with a glass pack or straight pipe or resonator dono what to do if anyone on here has heard what any sound like if its bad good ? and what would sound best? if you have any input let me know thanks, Luke
Old Mar 29, 2010 | 04:58 PM
TheePlaymaker's Avatar
TheePlaymaker
hard to get anything smaller than a V8 to "sound good" it will def be louder though idk how it will sound
Old Mar 29, 2010 | 05:23 PM
MadisonDakota's Avatar
MadisonDakota
It won't sound like a V8, but it doesn't have to sound bad.
Old Mar 29, 2010 | 06:01 PM
RoaminGnome's Avatar
RoaminGnome
Id be worried bout the low end loss, the 3.9 NEEDS back pressure or it has no grunt at low end. I almost want my stock cat back lol. Ill just mod more and compensate that way
Old Mar 29, 2010 | 07:11 PM
Me&MyMopar's Avatar
Me&MyMopar
I've been thinking about removing my cat as well, but I've been concerned about posts that I've read about losing low end. If I replace with a straight pipe, would I indeed lose low end, or not with the 360?
Old Mar 29, 2010 | 07:50 PM
RoaminGnome
Should be fine with the 5.9, its mainly the 3.9 that NEEDS the back pressure. Could be wrong tho, if you lose a lil low end it would probably be minimal.
Old Mar 29, 2010 | 08:45 PM
wewanaplay's Avatar
wewanaplay
oh no, this has been debated over and over and over and over and over. there have been several threads in here about exhaust. My advice is to search and read up on it and make your own decision.
Old Mar 31, 2010 | 11:02 AM
crateampsrock's Avatar
crateampsrock
you guys are failing to realize, all states have a law requiring catalytic converters, if the vehicle was originally equipped, They are required to pass most inspections. plus unless you rig it up right, you'll have a check engine light on. Not to mention it will indeed sound like a tug boat.
Old Mar 31, 2010 | 12:31 PM
TheePlaymaker
i don't think it will throw a code since there aren't any O2 sensors after the cat or on it their all before it if i remember reading right from past post as far as the code i know for sure theres no sensors after or on the cat
Old Mar 31, 2010 | 01:36 PM
Me&MyMopar's Avatar
Me&MyMopar
My truck has both the upstream, and downstream o2 sensors, but my plan was to use the nonfouler trick for the downstream sensor. There's no emissions testing in my area, so I'm not concerned about that. I'm not sure yet what I'm going to do though. I've read that with certain mods, your low end is just fine. I need to do some more reading when I get the time.
