Anyone change U Joints without a press?
Old May 19, 2010 | 12:20 PM
dbilik's Avatar
dbilik
Default Anyone change U Joints without a press?
I am going to try and change my U joints on the rear propeller shaft of my 2001 Quad Cab 4X4. Just wanted to see if anyone has changed these out before without a press. Thanks.
Old May 19, 2010 | 12:51 PM
crateampsrock's Avatar
crateampsrock
absolutely. They make a specialty tool that looks linda like a c-clamp that uses an impact and socket.
http://www.ntxtools.com/Merchant/gra...1/otc-7248.gif
Old May 19, 2010 | 02:13 PM
dbilik's Avatar
dbilik
I think that is a ball joint press. If that works I will rent one for free from autozone before I start the project. Thanks.
Old May 20, 2010 | 07:37 PM
984x4's Avatar
984x4
A sturdy vise, a couple of large drifts, and a BMF hammer. Did the joints on my old 4X4 Ranger. Should work on a Dak, too.
You can use the vise as a press, also. Just need some old sockets that are larger than the end caps of the joints.
Old May 21, 2010 | 12:03 AM
rpowell's Avatar
rpowell
I have never had to use a press for u-joints on any of my vehicles, haven't done them on my truck yet, but they look pretty straight forward to me.
Old May 21, 2010 | 12:09 AM
crateampsrock
that tool i linked before is a U-JOINT puller and pusher... thats what its called... they look alike and do the same function...
Old May 21, 2010 | 12:13 AM
jake7's Avatar
jake7
I used a large socket and hammered them into that....it worked...ha
Old May 21, 2010 | 01:03 PM
Az93DKota's Avatar
Az93DKota
X2 Along with a BFH. You'll have it done in 10 minutes.
Old May 21, 2010 | 05:57 PM
deranged's Avatar
deranged
X3. Just make sure everything is clean and grit free. Pack a little grease in the cap to hold the needles and be patient but firm with them. Don't forget to reward yourself with a few beers afterwards for a job well done!
