torque converter stuck
Old May 22, 2010 | 03:20 PM
984x4dakota's Avatar
984x4dakota
Default torque converter stuck
installed my engine wrong w/ the torque converter mounted on the engine as if it were a 5 speed. "idiot". anyways my torque converters stuck i tryed wiggling for two days nothing happened.. so i cut it out. but the front is still stuck. ive opted to ask for input on why it maybe stuck ive uploaded photos.. hopefully i havent done anything to the trans. any info appreciated.. thank you
98 dodge dakota 4x4 3.9l v6
engine 2002 3.9l v6
trans- whatever comes stock in a 98 dakota 4x4
Old May 22, 2010 | 09:25 PM
984x4dakota
would like to add that the piece thats left in spins and move in and out about 1/4 inch but wont come out. any info about whats going on or what i can do will help. thanks again
Old May 23, 2010 | 06:15 PM
NYsteve's Avatar
NYsteve
i'd try heating it up and prying it off.
Old May 23, 2010 | 06:34 PM
Crazy4x4RT's Avatar
Crazy4x4RT
That sucks. Sounds like it is stuck on the spines. One is frayed or chipped. That is causing it to stick. If you haven't already try taking a brass punch and lightly hammer it out, hit the torque converter piece only. If not yea you can try heating it up then hitting it. A small air chisel only on low hit the TC piece only. If still nothing I would say get a small cut off wheel and go VERY slow on it. Cut it 2 times opposite ends down the middle. Don't cut all the way threw get it very thin. then try to rip it apart with your hands or use a screw driver or pliers to pull the sections apart. Again don't touch the splines.
Once it is off inspect the splines, clean then as necessary.
Old May 24, 2010 | 12:33 AM
984x4dakota
thanks will try this out.
