96 leafs in a 98 dak question
Old May 26, 2010 | 04:33 PM
rglr's Avatar
rglr
Default 96 leafs in a 98 dak question
I'm in the process of putting the 2550lb rear leaf springs from a '86-'96 dak into my '98. I'm taking pics and will post a write-up if anyone is interested.
The '96 leaf bushings take a 1/2" bolt and the '98 leaf bushings take a 9/16" bolt. I have to use the '96 bushings due to the difference in diameter of the leaf spring eyelet.
So, the question is: Will using the 1/2" bolt in the hole of the bracket designed for a 9/16" bolt cause problems down the road wrt wear? (I'm talking about the bolt hole in the bracket/hanger which is mounted to the frame)
Thanks
Old May 26, 2010 | 04:39 PM
ZAKMAN's Avatar
ZAKMAN
a simple fix might be to use a bushing but will the leafs lift the truck or just stiffer?
Old May 26, 2010 | 04:49 PM
rglr's Avatar
rglr
according to some info I found online it will actually lower the rear by 1-3/8"
The '96 spring is 1-3/4" thick with a 5-3/4" arch = 7.5"
The '98 spring is 1-9/16" thick with a 7-5/16" arch = 8-7/8"
Old May 26, 2010 | 11:29 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Where did you find that info? I would like to check out that site. Also I think the 2wd and 4wd rates will be different due to how they are mounted differently.
Old May 27, 2010 | 06:53 AM
rglr's Avatar
rglr
http://www.generalspringkc.com/index...arent=117&pg=1
this site has the more detailed info
http://www.sdtrucksprings.com/index....FZdM5Qod_CVlZw
Old May 28, 2010 | 02:01 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Cool thanks! Great info!
