How much weight will it handle
Old Jun 10, 2010 | 10:57 AM
gambler12's Avatar
gambler12
Default How much weight will it handle
I have a '98 dakota 4x4 with the 5.2 engine and auto. transmission. Noticed on a different thread that some of you guys at times load your truck down. If I'm right, they're rated as a half ton, but how much would it handle for a short haul.
Old Jun 10, 2010 | 07:31 PM
TheePlaymaker's Avatar
TheePlaymaker
it should all be in your owners manual i just read a article the other day that the ton ratings don't mean too much now a-days so thats the best place to check
Old Jun 10, 2010 | 08:13 PM
Independentfool's Avatar
Independentfool
http://www.allpar.com/trucks/dakota-tech.html
scroll all the way to the bottom.
Old Jun 10, 2010 | 11:30 PM
zanethan's Avatar
zanethan
A truck bed full of water...
Old Jun 11, 2010 | 03:08 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes the old 1/2 ton 3/4 ton 1 ton doesn't apply anymore. I actually don't think it ever did. It was just a name.
Here is a good post. Look at the payload amounts. Notice ALL are way above 1/2 a ton. 1 ton = 2,000lbs. 1/2 a ton = 1,000lbs
https://dodgeforum.com/forum/2nd-gen...ml#post1978626
Old Jun 11, 2010 | 10:18 AM
gambler12's Avatar
gambler12
So, am I correct in assuming that it is feasible to carry a ton load of wood pellets on my '98 reg. cab, 4x4, with a 5.2 engine , auto. trans. and 6.5' bed. I usually take my utility trailer and kinda split the load.
Old Jun 12, 2010 | 06:16 PM
Independentfool
it'll squat a bit, but yes you'll be fine.
