How to replace leaf spring shackles???
Subscribe
Sep 13, 2011 | 09:21 PM
Quote: Perfect time to do the torsion shackle lift if you haven't already done it.
Longer shackles on a 4x4 will lower it since the spring is over the axle. Using longer shackles only works on 2wd Daks where the spring is under the axle.
Reply 0
Sep 13, 2011 | 09:36 PM
Well maybe the Daks are setup differently then my Durango. I assumed they were the same since they both are on the same platform.
Reply 0
Sep 13, 2011 | 09:56 PM
Yeah, it's strange that 4wd Durangos have spring under axle. I don't know why they did that. Maybe because the Durango is more of a "passenger vehicle" and having it under might provide a little smoother ride and keep it closer to the ground.
Reply 0
Sep 14, 2011 | 08:06 AM
Drivers side is generally in worse shape...rule of thumb. Of course, my truck is backwards in that regard, but hey, what else would be my luck.
Reply 0
Subscribe
