HID Conversion help?
Old Jun 23, 2010 | 11:45 PM
SpencerS's Avatar
SpencerS
Default HID Conversion help?
So I am Fairly certain i want to do a 8k HId Conversion for my truck. However I want to be respectful to other drivers so i want to get the correct housing for them.
This is the kit i was looking at on ebay, any other suggestions for kits would be awesome.
http://cgi.ebay.com/ebaymotors/DODGE...ht_4390wt_1165
Now the only housing kit on ebay looks cheap and i would have to remove my clear corners. I Do not want to do this i just want to replace the headlamp light housing to make it legal and safe.
and any tips on installing the kit would be greatly appriciated since i am kinda flying blind here.
Thanks for your help guys!
on a side note got my 14" glasspack today, very loud in the cab lawl
Old Jun 24, 2010 | 12:49 AM
cowboy63645's Avatar
cowboy63645
If you do a search I am pretty sure they make just a headlight replacement in a projector style lens. I am not positive about that but I am pretty sure I have seen them cause I had them saved on ebay once or twice.
Old Jun 24, 2010 | 11:19 AM
dodgeramguy85's Avatar
dodgeramguy85
Ok well I did my Hid's about 3-4 months ago and this is the kit I got because another member on here(User) had it and he had no problems with it
http://www.mydepots.com/55w-hid-kit-bixenon-p-12.html
This is a 55watt Bixenon kit. Which that one on ebay was a 35 watt and I dont think it is bixenon but I could be wrong. With my kit that I have I rarely use highbeams I do on some occasions but not as often as when I had my stock lights. A could people on here will say respect other drivers and get different lenses if not you will blind other drivers which its true if you leave the headlight adjustment where it is for stock I currently have mine in my stock lenses but I have mine adjusted to where they wont blind other drivers in the like 3-5,000 miles I drove at night the last couple months I only got flashed 3 times. So before you go and spend 130.00 on new lenses adjust the ones on your truck down a bit and you will be fine.
Old Jun 24, 2010 | 12:26 PM
SpencerS's Avatar
SpencerS
and how will I go about adjusting them, is it that torx bit right near the head lights?
also I have a slight problem, for some reason my truck has daytime driving lights which i am assuming is not good for HID purposes. How would i go about disabling the day time driving lights.
They come on when i switch the light switch to off.
Old Jun 24, 2010 | 12:37 PM
SpencerS's Avatar
SpencerS
I am not sure but I have been told by alot of people that HID's are illegal in bellhousings not meant for HIDs. Again not 100% sure!
Old Jun 24, 2010 | 12:38 PM
dodgeramguy85
I think its a torx but not sure ill have to go out and look at my truck and the running lights Im pretty sure that it means your truck came from Canada because they have to have that and if you take it to a dealer they might be able to go into the computer and change it but really it shouldn't effect your hids its basically like running with parking lights and fogs on I do it all the time.
Edit: Not sure about the whole illegal thing
Old Jun 24, 2010 | 12:49 PM
SpencerS's Avatar
SpencerS
True but the HID bulbs would be running all the time wouldnt they? or is that something separate?
Old Jun 24, 2010 | 01:01 PM
cowboy63645
You need a DRL killer, basically all it is, is one little wire that you put in your truck that over rides your daytime running lights. Fairly simple to do, I will see if I can fnd a link for them for ya.
Old Jun 24, 2010 | 01:06 PM
dodgeramguy85
But when the running lights are on isnt it only your fogs and parking lights or is it headlights and all?
Old Jun 24, 2010 | 01:08 PM
SpencerS's Avatar
SpencerS
Ok heres what i found out about HIDs in stock bellhousings
http://isearch.nhtsa.gov/files/Shih.3.html
They are illegal to put in stock bell housings that were made for halogen bulbs. So I will have to find some HID compliant bellhousings if i wanted to be completely legal. I probably could slip by law enforcement but it is a shoot and miss situation since where i live there is quite a few street racing gangs around.
EDIT: Just the head lights are on and its dimmer than even my low beams.
