re-gear?
Old Jun 24, 2010 | 01:59 PM
xxtnxx's Avatar
xxtnxx
Default re-gear?
I have a 2002 Quad cab Dakota 4.7L v8 2wd with a 3" body lift (going on this monday) 2" shackles in back and 1" spacers up front. I'm going to be running 285/75/16 (33" tires) on a set of 16x8 cragars, I'm not going to have to re-gear am I? For some reason I believe I recalled reading that you would/should have to re-gear for 33's..
thanks in advance.
Old Jun 25, 2010 | 01:47 AM
Hahns5.2's Avatar
Hahns5.2
You don't have to, but you should. I'd get 4.56s.
Old Jun 25, 2010 | 04:48 AM
magnethead's Avatar
magnethead
I'm on 32's (265/75/16) on stock 2wd gears. speedo is fairly off though. tirerack says the stock tire is a 235 something, 29" tall.
Old Jun 25, 2010 | 09:24 AM
dodgeramguy85's Avatar
dodgeramguy85
I wouldnt swap it loss of a little acceleration but not that big of a deal
Old Jun 25, 2010 | 12:24 PM
Hahns5.2's Avatar
Hahns5.2
And fuel mileage, more wear and tear on the tranny or clutch. Do what you want but improper gearing a huge pet peeve of mine. Do it right.
Old Jun 25, 2010 | 01:55 PM
magnethead's Avatar
magnethead
My V6 hasn't changed much at all with the 32's. Yea my combined MPG went down, but only from 16 to 15. And that's considering I have a V8 TB sitting under my dresser, and it probably needs new injectors and plugs. And i've been going a year with the CEL on for the infamous evap code.
