Daytime running lights switchable?
Old Aug 11, 2010 | 05:15 AM
dzuehlke's Avatar
dzuehlke
Default Daytime running lights switchable?
I have a 2000 Dakota. In Canada daytime running lights are always active in the US version not. Is there a simple way to just reprogram a controller to switch this feature on? Or does it need some extra parts like relays to be activated? Answers to this questions can be found here but always for newer and different models.
Thanks Det
Old Aug 11, 2010 | 11:39 AM
dodgeramguy85's Avatar
dodgeramguy85
Im pretty sure dealer is the only one who can change it.
Old Aug 11, 2010 | 07:47 PM
magnethead's Avatar
magnethead
what lights are used for DRL's? the turn signals, or the fogs? Are the tailmaps illuminated as well?
Old Aug 11, 2010 | 10:12 PM
dodgeramguy85
Im pretty sure it just acts the same like when you have the lights on normally.
Old Aug 12, 2010 | 12:29 AM
magnethead's Avatar
magnethead
so corner lamps only, or corner lamps plus (dimmed?) headlights?
Old Aug 12, 2010 | 12:49 PM
SpencerS's Avatar
SpencerS
my DRLs are just dimmed headlights.
Old Aug 12, 2010 | 09:11 PM
Rantz's Avatar
Rantz
My old truck's DRLs were just dimmed headlights as well. Current one doesn't have DRL.
Old Aug 12, 2010 | 09:19 PM
magnethead's Avatar
magnethead
then what, exactly is the gain from turning it on? I prefer parking lamps + fogs, myself.
Old Aug 12, 2010 | 10:04 PM
Rantz's Avatar
Rantz
It would just be for increased visibility to other drivers for better safety.
I would also like to figure out how to turn them on. Except I would look into rigging my parking and fogs to turn on instead. I'm with Mag the Ad on this one. I'm thinking about adding some LED accents to my headlight assembly and I would want those to be on as well.
Thoughts?
**Edit**
Where can I find instructions on how to enable my daytime running lamps? I just ran a search of the forum and haven't figured it out. Link someone?
Old Aug 13, 2010 | 12:15 AM
magnethead's Avatar
magnethead
Thoughts?
**Edit**
DRL is a dealer deal- and rarely will they do it for you. It's a modification to the computer program.
What i'm thinking about doing, is getting those $25 driving lights from O'Reilly's, and putting those on the lower valence somewhere, and connect them to the factory fogs via relay, triggered by an on-off switch in the cab somewhere (factory fog switch would be nice, but it dies when high beams are on). Then take the wire triggering all 4 fogs, the parking lamp wire, and put a DPDT between them, actuated by ignition_on. That way, if the key is on, the parking lamps and factory fogs are on. Then, i can flip the cab switch on, and have the driving lights as well. Plus, it will keep everything on when high beams are on, so i'll have high beams, fogs, and driving lights (6 lights total).
I'm just not sure where to put my switch for driving lights. In my old truck (1977 GMC), I got an ashtray from the junkyard, and screwed a cover on it, with 3 switches in it. That way, if I put the ash tray up, you didn't see the switches. But my ash tray in my dako is broke (won't open), so that won't quite work.
