best shocks for a 01 dak 4wd qc?
Old Aug 21, 2010 | 05:47 PM
j2048b's Avatar
j2048b
Default best shocks for a 01 dak 4wd qc?
i have run bilstein, monroe, and a few others and still feels like crap when drivin! squirly over rail road tracks, and bouncy every where else, every little bump is hit and feels like i am hitting mini potholes!
what brand and part # is the best to help in this ?
i have yet to try rancho, some say put the 5000 series on the back and something different on the front?
what about the self adjusting ranchos?
any info appreciated!
thanks
Old Aug 24, 2010 | 08:46 PM
wingerak92's Avatar
wingerak92
Don't know what Bilsteins you tried, but I found them to be the best of the bunch. You sound like you are looking for softer shocks. I like the stiffness as it helps on washboard. I put bBilsteins on mine and any gravel road, or bump doesn't send my back end sideways anymore
Old Aug 25, 2010 | 04:55 AM
j2048b's Avatar
j2048b
cant remember which ones i bought either this set: from shox.com
BE5-2617-H0 &
B5-A702-H0
or this set:
BE5-2617-H0 &
BE5-2618-HO
always wondered about the rancho's which kind were the self adjusting? 5000 series?
Old Aug 25, 2010 | 01:28 PM
SpencerS's Avatar
SpencerS
ranchos kinda have a problem with sheering off bolts on some of the models. Just be wary!
Old Aug 25, 2010 | 01:36 PM
thunder98110's Avatar
thunder98110
you can just get a grade 8 bolt to fix that problem. i have procomp es9000 much better than the pos stockers that i had on there.
Old Aug 25, 2010 | 04:29 PM
j2048b's Avatar
j2048b
thanks for the heads up,
what part #'s would i try to go with for rancho's? also what # for procomp?
i want something that is self adjusting and makes my ride smoother! i have bilsteins currently, and was told they were awesome, maybe my whole suspension just sucks and the shocks are fine?
gona be changing out both sides lower and upper ball joints, inner and outter tie rods, and after that i will prolly change out my bushings all over the place!
any good numbers for bushings you guys know of for an 01 dak 4x4 qc?
Old Aug 25, 2010 | 05:56 PM
SpencerS's Avatar
SpencerS
have you cranked your torsion bars?
if they are then thats why your ride sucks, the crank makes it ride alot rougher. When i hit a pot hole going more than 20 or hit some uneven road ive had my backend get all squirlly and loose traction.
haha its not fun!
Old Aug 26, 2010 | 12:27 PM
j2048b's Avatar
j2048b
haha its not fun!
i dont believe i have cranked them, i had a tire guy who was doing my alignment, FINALLY do it as the book from chrysler recommended and he said he had to adjust them a bit due to my truck not being level and or one side being a bit higher than the other, but never intentually cranked them for ride height purposes!
