engine code 302- rough idle
Old Aug 29, 2010 | 06:24 PM
rlloz's Avatar
rlloz
Default engine code 302- rough idle
Hi...I'm new to the forum. I have the check engine code #302. So I swapped #1 coil to #2..but still have the error code, could the injector be the culprit?
It sucks because i loaned my 2001 Dakota 4.7 to roomie and THEN the code came on!! I love my truck,,, but i might have to strangle my friend!!!
Thanx for any input!!
Robert
Old Aug 29, 2010 | 09:08 PM
McNasy's Avatar
McNasy
just my opinion, clear the code via a code reader. if it still returns, i would say its the injector. either it got a quick blockage or it went to crap on you. i am sure there will be more input(better input) after mine. btw, welcome to the forum! you will find this forum most informative.
Old Aug 29, 2010 | 10:58 PM
thunder98110's Avatar
thunder98110
the only advice i can offer is to disconnect the negative side of the battery terminal for a few minutes to reset the computer. then after about 2 days of driving see if it comes back. it probably wont pop up right away, the pcm needs to learn the new settings which takes like 6 starts.
Old Aug 29, 2010 | 11:15 PM
McNasy's Avatar
McNasy
the ecm and pcm and bcm need to see 3 cycles of no codes to clear itself. unless you clear it with a reader. i do believe a cycle is more than 20 miles on a run. disconnecting the battery does not clear hard codes in the ecm.
Old Aug 30, 2010 | 12:11 AM
Rantz's Avatar
Rantz
All of these abbreviations! Can we also include a legend please? lol
Old Aug 30, 2010 | 06:31 AM
hemifever's Avatar
hemifever
SPONSOR
As McNasy said, a faulty injector can also cause that code. Swap it with another and see if anything changes.
Old Aug 30, 2010 | 09:24 AM
twitchy's Avatar
twitchy
haha,
if you're serious, I stumbled upon this list last week pokin' around the forums.
https://dodgeforum.com/forum/new-mem...eviations.html
Old Oct 2, 2010 | 04:56 AM
rlloz's Avatar
rlloz
Default dakota error code 302
I changed all 8 injectors...solved the problem...bought them @ Ebay
