rusted spark plugs
Old Sep 3, 2010 | 10:36 PM
SpencerS's Avatar
SpencerS
if that doesnt work any resonable machine shop will drill a spark plug out for about 20 bucks per plug!
Good luck!
Old Sep 7, 2010 | 12:02 AM
wlkingdead's Avatar
wlkingdead
thanks everyone for all the advice. the issue isn't removing the plug, all the others came out just fine, the issue is being able to even get the 5/8 on the nut itself. i was hoping for a product that would break down the rust enough to just get the socket on, and hopefully something that wouldn't hurt if a little make its way into the chamber.
Old Sep 30, 2012 | 11:55 AM
Tailgate101's Avatar
Tailgate101
I had a similar issue on my 5.9. 3 days in a row when I got home from work, I hit it with PB blaster while it was hot (so it would suck in better). Each time I used an air blower to blow out what I could before soaking it again. I also used a long thin flat tip screwdriver to chip away what I could. After the 3rd day, I let it cool down, and didn't have a problem.
Old Sep 30, 2012 | 01:40 PM
UWAdventurer's Avatar
UWAdventurer
Did you try a metric socket that would be a hair larger?
