Squeeking from rear while accelerating...
Old Sep 23, 2010 | 01:27 PM
gtmaxey's Avatar
gtmaxey
Default Squeeking from rear while accelerating...
So I hear a squeak, replace the tensioner and idler pulleys. still squeaks, drove up the road with my head out the window...and dang, I misdiagnosed, the squeak is from the rear and is getting worse by the day. Only occurs when I accelerate forward, nothing in reverse. I am leaning towards breaks???
Old Sep 23, 2010 | 01:57 PM
midget-farms's Avatar
midget-farms
Could be brakes - check the u-joint in the drive shaft.
Ujoints will squeek once per rotation in a repeating squeek, squeek that accelerates with speed.
If its a constant squeek - probably thin pads & the wear indicator rubbing the disk.
Old Sep 23, 2010 | 02:24 PM
gtmaxey's Avatar
gtmaxey
Thanks, I will check both of those out this afternoon. I appreciate it.
Old Sep 23, 2010 | 02:45 PM
thunder98110's Avatar
thunder98110
could be shocks or sway bar in the rear, i know my sway bars make a lot of noise.
Old Sep 23, 2010 | 06:50 PM
magnethead's Avatar
magnethead
I was thinking leaf shackle bushings myself, if such a condition exists?
Old Sep 24, 2010 | 10:23 AM
gtmaxey's Avatar
gtmaxey
Thumbs up
U Joint it is...Thanks!
