best way to seafoam?
Old Sep 25, 2010 | 10:10 PM
wlkingdead's Avatar
wlkingdead
Default best way to seafoam?
i got a 98 3.9 sport and was wondering what is the best way to run seafoam through the intake? right down the TB or through the brake booster vacuum?
Old Sep 25, 2010 | 10:14 PM
jake7's Avatar
jake7
A lot use the brake booster.. try using the search function. TONS of info about seafoam.
Old Sep 25, 2010 | 10:34 PM
dbilik's Avatar
dbilik
Brake booster if you want to run it into your intake. You can also use it in the gas tank and the oil.
Old Sep 25, 2010 | 10:35 PM
thunder98110's Avatar
thunder98110
gas tank, down the brake booster, and crankcase. some say to change oil after crankcase but its up to you. if you want a smoke show do it in the crankcase.
Old Sep 26, 2010 | 12:02 AM
dakota19762's Avatar
dakota19762
Did mine, here is the video. Ran good.
http://www.youtube.com/watch?v=WrDzocur91A
Old Sep 26, 2010 | 02:47 PM
bpark8824's Avatar
bpark8824
You just took the hose out of the booster and put it in the seaform container and let it suck it up? How did it work? Notice any difference?
Old Sep 26, 2010 | 02:55 PM
00dakSport's Avatar
00dakSport
bpark, thats what i did but its easier to put it in a cup or somthing first (sip it slow). after you let it sit for 30 minutes and start it up it should smoke out the tail pipe. did mine at 90k and got some smoke.
Old Sep 26, 2010 | 02:56 PM
bpark8824's Avatar
bpark8824
Old Sep 26, 2010 | 03:00 PM
00dakSport's Avatar
00dakSport
i wasn't smoking the tires or anything. maybe like when you change the oil. and my mpg's are all over the place cause of traffic.
Old Sep 26, 2010 | 06:45 PM
thunder98110
brake booster is useless imo, better to just spray carb cleaner there. if you want it cleaner do crankcase. it burns up almost instantly when u do it in the tb,
