DIY rear sway bar links and bushings *Pic heavy*
Old Jan 22, 2011 | 02:48 PM
  #41
Gasnmyveins's Avatar
Gasnmyveins
How about an update? I've heard that poly bushings will start to squeak after a while, but I don't know if the manufacturers have beaten that issue yet or not. Have you had any problems with that? When I do mine, I'll also be doing my control arm bushings. Since those are going to be no easy task, I really don't want to have to go through the whole procedure just to put rubber back in.
Thanks, Gas.
Old Jan 22, 2011 | 06:33 PM
  #42
thunder98110's Avatar
thunder98110
no complaints so far. still quiet.
Old Jan 23, 2011 | 11:16 PM
  #43
Gasnmyveins
Cool, thanks. I'll go ahead and use them, then.
Old Jan 24, 2011 | 08:05 AM
  #44
DakMan6704's Avatar
DakMan6704
I did this about a month ago...This with RS9000 shocks make it stiff!!!!
If you need front sway bushings and your dia is the same as mine(33mm maybe) I have a set that Rock sent me double of, and well, its not worth it to send em back.
Old Jan 25, 2011 | 10:52 PM
  #45
Gasnmyveins
Thanks, I'll have to check the size of the bar soon.
I see you're from Pa. That wouldn't happen to be the western side, would it?
Old Jan 26, 2011 | 12:15 PM
  #46
DakMan6704's Avatar
DakMan6704
Nope...like 45min west of philly...
Old Jan 27, 2011 | 10:21 AM
  #47
Gasnmyveins
I'm from the western side, and I can guarantee you that it's absolutely insane up there right now. I was there just before SB XL, and people had stands set up next to streets, out in the winter cold and wind, selling Steeler stuff. You couldn't turn on the news without half of it being devoted to the Steelers. It was great, and I wish I was up there right now. Last time, I had to leave the day before the game. Man, I'd LOVE to watch a Steelers SB in a sports bar full of foaming-at-the-mouth western PA fans. I'd be hoarse for a week.
Old Sep 20, 2011 | 10:39 PM
  #48
chris1996's Avatar
chris1996
Originally Posted by thunder98110
i looked at the photo you posted of your rear diff, and it looks like you have the mounting points for them on the axle but no sway bar. weird.
me two my truck didnt have it have some kind of supports
