Rpms fluctuating
Old Nov 9, 2010 | 11:09 AM
dodgeramguy85's Avatar
dodgeramguy85
Default Rpms fluctuating
Well recently I noticed that my problem that only showed its face every once and awhile is now here for good well 90% of the time it is. Every time I drive my truck it runs great shifts great but almost everytime I let off the gas my rpms drop then picks back up and drop again and it will do this until I get back on the gas this is really noticable at 50mph or above. Im not throwing any other codes other than my usaual evap code. I did notice the other night it was doing it then on my way home I was passing cars left and right one point I think I hit about 100 and after that it wasnt doing it. I have no clue what to even look for Tps?
Old Nov 9, 2010 | 12:46 PM
thunder98110's Avatar
thunder98110
tps could be going bad. check the voltage and report back.
Old Nov 9, 2010 | 01:40 PM
dodgeramguy85
I will when I find my meter tryin to think who I lent it out to last lol
Old Nov 9, 2010 | 04:43 PM
corpusfisherman's Avatar
corpusfisherman
sounds like that good old crankshaft position sensor. only way to test that stupid intermittent problem part is to replace it, which isn't hard.
Old Nov 9, 2010 | 08:07 PM
dodgeramguy85
Found out my buddy has my meter so ill post back tom around 5 or so Im hoping my tps is bad but I doubt it.
Old Nov 9, 2010 | 11:05 PM
a-hall's Avatar
a-hall
If it were mine i would replace the Throtle position sensor, idle air control, and the crankshaft position sensor. Mine never surged like that but one day it started then died. Sure enough the crankshaft sensor went out. I would be willing to bet a new TPS would fix it but while your doing that i would do the others. (just my .02cents)
Old Nov 9, 2010 | 11:19 PM
dodgeramguy85
Im cheap I try to save money where I can if I get a tps and it doesnt fix it then back it goes until I find the part that fixes my problem lol. I dont think its my crank sensor but we will see for sure still need to do couple things before winter comes.
Old Nov 15, 2010 | 12:13 AM
dodgeramguy85
UPDATE!!
Sorry for taking so long I've been busy was supposed to test my tps fri but ended up hunting all day fri and sat finally got around to testing it and it seems fine. Been driving it all this weekend and rpms dont move as much as they did before when I let off ill see a drop of 50-100 rpms then it will come up its not near as bad as before. No sure what the prob might be its not too bad right now(knock on wood) I can stand that.
