heater no workie!!!!
Old Nov 23, 2010 | 12:22 PM
bill9000's Avatar
bill9000
Default heater no workie!!!!
Hey all, I've been talking to some folks locally who also have dakotas (I have 97 Dakota Sport) - and the heater doesnt work, just nothing but cold air... seems they have an issue with this... does anyone know a common heater problem with these and what to do?
- Happy Holidays!
Old Nov 23, 2010 | 12:33 PM
01SilverCC's Avatar
01SilverCC
It's a common problem. The heater core is probably plugged up with goo and gelled antifreeze. You can disconnect both heater hoses, direct one into a 5-gallon bucket and use a water hose directed into the other hose to flush the junk out. Flush it one direction for a few minutes then reverse the hoses and flush in the opposite direction. Do this until the water runs clear out of each heater hose. This would also be a very good time to flush out the entire coolant system, add new coolant and replace your radiator hoses and hose clamps and install a new thermostat too.
Old Nov 23, 2010 | 01:45 PM
dodgeramguy85's Avatar
dodgeramguy85
I flushed my heater core couple weeks ago took me 10 min to do it and what a big difference it made.
Old Nov 23, 2010 | 01:54 PM
bill9000's Avatar
bill9000
ok, now I've done that, I bought an adapter for my garden hose that fits the heater hose, and did flush it both ways, and it was all gunky... but... heater still doesnt work.
maybe it;s worth nothing, the truck also has 181,000 miles, is it possible the engine is loose, worn and not building enough heat? - I notice the engine temp gauge doesnt show it running very warm, maybe 180?
Old Nov 23, 2010 | 01:58 PM
01SilverCC's Avatar
01SilverCC
Thermostat is probably stuck closed. If it's original or old, replace it.
Jimmy
Old Nov 23, 2010 | 02:01 PM
dodgeramguy85
my truck runs 180 all the time. Im thinking could be a theromostat but normally if they get stuck in the closed position your guage temp is higher than normal. Could be heater controls not working right did u try all settings?
Old Nov 23, 2010 | 02:11 PM
bill9000's Avatar
bill9000
my truck runs 180 all the time. Im thinking could be a thermostat but normally if they get stuck in the closed position your gauge temp is higher than normal. Could be heater controls not working right did u try all settings?
I've messed with the heater *****... it's just cold air.... I am wondering, if maybe I should buy a heater core and replace it... but wonder how difficult a job that is, sometimes they are horrible, and some vehicles easy...
I am also trying to buy a new long block engine right now, because I can't trust the mileage on this one, but fearful even after new engine, still no heat, and it's supposed to be 6 degrees here tomorrow! LOL, no way of defrosting windows...
Old Nov 23, 2010 | 02:45 PM
dodgeramguy85
It could be the blend door dodges have a problem with them breaking. How long ago has it been since you had heat? The heater core might be fine unless you smell a sweet smell when in your truck. I did one in a ram and it was pretty easy but in the daks its worse cause its like right in the middle the whole dash has to unbolt and slide back a lot of guys take their front seats out so they have more room to work.
Old Nov 23, 2010 | 03:04 PM
bill9000's Avatar
bill9000
hmmm blend door, now that sounds like it could certainly be something!!!! - how would I determine if that is the prob? - and I've never had heat in the truck, for the 2 years I've had it. it came this way. (I bought it reallll cheap!)
Old Nov 23, 2010 | 03:31 PM
dodgeramguy85
Im not really sure never had to deal with it. Im sure someone else on here knows
