Transfer Case Problem 02 Dakota 4.7 Auto
Old Dec 10, 2010 | 09:36 PM
EricBing's Avatar
EricBing
Default Transfer Case Problem 02 Dakota 4.7 Auto
Just got transfer case rebuilt, now service 4 wheel light comes on after 20-30 secs after starting truck, but all my indicator lights come on, upon starting, then go out and wont shift into 4 hi or lo...2002 Dakota, NP 233D, 4.7 liter, automatic, possible sensor problem or decoder motor, any help would be appreciated
Old Dec 10, 2010 | 10:04 PM
magnethead's Avatar
magnethead
first thing would be to make sure everything is reconnected correctly.
Old Dec 10, 2010 | 10:33 PM
EricBing's Avatar
EricBing
yes, double checked everything is connected properly and cleaned thoroughly with contact cleaner
Old Dec 10, 2010 | 11:40 PM
magnethead's Avatar
magnethead
Can you hear the solenoids energzing or anything when you move through the modes on the selector?
Old Dec 11, 2010 | 06:56 PM
EricBing's Avatar
EricBing
i hear nothing energizing or activating, the lights dont even indicate which mode i am in, the lights come on at start up, then go off , then 15-20 secs later service 4 wheel indicator on dash comes on, screwy thing about it is everything worked fine before rebuild, and Driveline Advantage did only mechanical work to case(which was cracked in 3 places so they rebuilt internals)
Old Dec 11, 2010 | 07:03 PM
magnethead's Avatar
magnethead
awfully sounds like a wire came off or something. have you taken it back to them?
Old Dec 11, 2010 | 07:16 PM
EricBing's Avatar
EricBing
yes i took it back only to be told, they only did mechanical work to transfer case, i removed and installed t-case my self, saved around 400, i was wondering if it could be the sensor on side of t-case, dont wanna start throwing parts at it
Old Dec 11, 2010 | 07:23 PM
magnethead's Avatar
magnethead
ok, so you didnt actually give them the truck, just the case? I was thinking maybe they fiddle'd with the dash switch or something.
Old Dec 11, 2010 | 07:27 PM
EricBing's Avatar
EricBing
that is why i was leaning toward the sensor, but i hope it's not the motor those r a lil pricey lol, trying to find a check for either/or to isolate the problem
Old Dec 11, 2010 | 07:30 PM
magnethead's Avatar
magnethead
Sensor, like everything else, probably has a voltage that you can read. I'm only a 2wd so I cant help much there...
