Need Heat
Old Dec 15, 2010 | 05:52 PM
DodgeLives's Avatar
DodgeLives
Default Need Heat
Has anyone ever removed the A/C Heater housing, do you have to remove the dash? My heater is not blowing heat, the heater core has been flushed and flows good both ways. Engine temp is running 188 deg. Factory manual states the air should be 160 deg. out the vent, mine is barely 90 deg. I'm thinking either the Temp control door is not moving all the way or leaves and trash has stopped up the core so air can't blow through it. Any help will be greatly appreciated.
Charlie
Old Dec 16, 2010 | 12:37 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Probably not the Entire dash, but quite a bit that is under there. The service manual is in the Stickies at the Top of this section. It has a complete description of the brake down on how to remove it all.
Old Dec 29, 2010 | 04:23 AM
dakotagal's Avatar
dakotagal
did you ever get that heating problem fixed. I am having the same issue. from what I have heard, it could be the heater core and the entire dash has to come out in order to get to it. My problem is still not fixed
