Front Sway Bushings
Old Dec 20, 2010 | 10:46 AM
DakMan6704's Avatar
DakMan6704
Default Front Sway Bushings
Hey guys...I tried poking around past posts, and have run into a dilemma...I want to do my front bushings, but have no really good feelings about them. Looking between local store(nothing in stock) and Rockauto, I don't get the warm and fuzzies about either. I picked up the rear bushings from Moog, and they were the 'right' part number, but the wrong dia inside. I put stock back in. I dont want to run around, and pull the parts on the truck 35 times.
So, looking at 33mm front bars, and 16mm rear. 4x4 truck...Found these:
Front:
Inner Bushings(frame) - Moog P/N K7383 (lists RWD, but looks fine to me)
Outer(a-arm) - Moog 1.3" P/N K200162; Rabestos P/N 5501591 - Listed 1.3"(1.2992=33mm)
Rear:
Endlinks - Done - Moog P/N K80244
Inner - Moog P/N K3160 - Ones from Advance were wrong(forgot to measure).
Am I missing something? I found the Moog front outer on thier catalog...Ill call around to see if they are around. Any inaccuracies, please let me know.
Old Dec 20, 2010 | 10:57 AM
thunder98110's Avatar
thunder98110
the rears are 16mm. fronts i think they are 1.3" diameter. rockauto is the place to go.
https://dodgeforum.com/forum/2nd-gen...pic-heavy.html
Old Dec 20, 2010 | 10:58 AM
thunder98110
https://dodgeforum.com/forum/2nd-gen...g-install.html
Old Dec 20, 2010 | 11:13 AM
DakMan6704's Avatar
DakMan6704
Figures you'd respond...lol I saw your writeup for the rear....I should learn to type and read...to see the front that is...maybe Ill order, hope Moog isnt lying to me w/part numbers and hope for the best. If not...prothane will result!
Thanks again for the pointers..seems like with more parts stores, its harder to find the right part! Get some rockauto love going, return the endlinks to Advance..2x the cost...christ...
