Engine won't start
Old Dec 31, 2010 | 11:14 AM
spanishgrass's Avatar
spanishgrass
Default Engine won't start
I recently removed the auto trans to replace the freeze plugs and reinstalled tranny, job went well, now engine refuses to start. I did forget to disconnect the battery and the starter terminals manage to make contact with the frame. Apparently I blew a fuse somewhere. I have pulled every fuse that is visible and none are blown. There is no spark at the coil. Is there a fuse somewhere other than in the obvious fuse boxes, inside dash panel and underhood, that i'm missing.Vehicle is a 97.
Old Dec 31, 2010 | 01:08 PM
cowboy63645's Avatar
cowboy63645
Look for in-line fuses in the wires. That will be your problem. I did the same thing on a 95 dakota and it ended up being an inline fuse.
Old Jan 2, 2011 | 10:23 AM
spanishgrass
Does anybody have anyidea where the fuse in question might be?
Old Jan 2, 2011 | 11:14 AM
cowboy63645
If I can get to it, I will try to get a couple pictures of them.
Old Jan 2, 2011 | 11:35 AM
bwdakrt's Avatar
bwdakrt
Inside the PDC fuse box under the hood, look for the ASD (Automatic Shutdown Relay) and swap it out for another known to be good relay inside the fuse box. You may have shorted it out when the battery cables got together. Also check the main fuse, I believe its a 140 amp, in the fuse box also. Good luck!
Old Jan 4, 2011 | 03:12 PM
bloodh15's Avatar
bloodh15
agreeed X2. this is usually the issue.
Old Jan 4, 2011 | 04:42 PM
wewanaplay's Avatar
wewanaplay
Seems like you can also bypass the ASD to troubleshoot too.
Old Jan 4, 2011 | 07:00 PM
spanishgrass
All the afore mentioned fuses have been replaced with new ones. No luck. There must be an inline fuse somewhere in the system. I simply can't locate it. The manual is of no help.
Old Jan 4, 2011 | 08:04 PM
wewanaplay's Avatar
wewanaplay
Wait a minute? Your engine rotates but just wont start??? or does it even rotate?
Old Jan 4, 2011 | 08:16 PM
spanishgrass
Engine cranks, all lights work, fuel pump works, all dash lights work, but there is no spark at the coil or dist.
