build sheet
Old Jan 5, 2011 | 01:28 AM
cbassj8's Avatar
cbassj8
Default build sheet
I just got my build sheet from dodge and was looking to see if I have a LSD I dont see it. Am I missing something when I read it?
*K5 Cloth High-Back Bucket Seats
-DV Dark Slate Gray
ADAS Light Group
AGBP Tire and Handling Group
AJKP Convenience Group
AJPP Power Convenience Group
APAS Monotone Paint
ASPP SLT Decor Group
ATK SLT Plus Decor Group
A29P 4.7L Engine(EVA)/4Spd A/T 45RFE(DG4)
BAZP 136 Amp Alternator
BCES 600 Amp Maintenance Free Battery
BGJS Pwr Disc/Drum Rr Anti-Lock Brakes
BKAS 11x2 Rear Drum Brakes
CADP High Back Bucket Seats
CBPP Cloth Door Trim Panel w/Map Pocket
CFFS 2nd Rear Bench 3 Pass/Fold Seat
CGWS Next Generation Front Air Bags**
CKES Front Seat Area Carpet
CLEP Front & Rear Floor Mats
CSRS Passenger Assist Handles
CSWS Driver Assist Handle
CUCP Floor Console
CUDP Mini Overhead Console
DGBS All 4-Speed Automatic Transmissions
DG4 Multi-Speed Auto 45RFE Transmission
DHAP Lock-Up Torque Converter
DHTS Elec,Shift-on-the-Fly,P/Time T/Case
DJDS 205MM Front Axle
DMDS 3.55 Rear Axle Ratio
DRBP Corporate 9.25 LD Rear Axle
EAAC All Engines
EVA 4.7L V8 MPI Engine
GACS Tinted Glass Windows
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GEGS Deep Tint Sunscreen Glass
GJDS Rear Fixed Window
GNAS Rear View Day/Night Mirror
GNDS Driver Side Sun Visor
GNES Passenger Side Sun Visor w/Mirror
GURP Power Mirrors
GVBC All Vehicles W/Power Mirrors
GXRP Keyless Entry
HAAP Air Conditioning
I89S Route 89 - CSX, Selkirk, NY
JAYS Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJP 12V Auxiliary Power Outlet
JPBP Power Locks
JPDP Power Windows, Driver One-Touch
KRXS STRIPE/BADGE/MOLDING/COLOR
KTXS STRIPE/BADGE/MOLDING/COLOR
K2AP STRIPE/BADGE/MOLDING/COLOR
LBCP Glove Box Lamp
LBDP Ash Tray Lamp
LCDP Map/Dome Reading Lamps
LMBS Halogen Headlamps
LPEP Cargo Lamp
LPSS CHMSL Lamp
MBBP Bright Front Bumper
MBFP Bright Rear Bumper
MDAP Front License Plate Bracket
MFDP Bright Grille
MHAS Black Windshield Moldings
MLCP Gray Fascias
MUMP Dakota Badge
MUZP SLT Badge
NAS 50 State Emissions
NBKS EVAP Control System
NFES 24 Gallon Fuel Tank
NHMP Speed Control
PSB Bright Silver Metallic Clear Coat
QSBS Bright Silver Metallic Clear Coat
RAAC All Radio Equipped Vehicles
RASS AM/FM Cassette Radio
RCDP 4 Speakers
RDDS Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCDS Luxury Steering Wheel
SDBS Heavy Duty Suspension
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SHCP Front and Rear Stabilizer Bars
SUAP Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TXVP P265/70R16 OWL All Terrain Tires
TZAP Goodyear Brand Tires
WD1P 16X8.0 Cast Aluminum Wheels
WKBP Matching Spare Wheel
WLZC All Aluminum Wheels
XBSS Pickup Box
YAAS Build To U.S. Mkt. Specifications
YEP Manuf Statement of Origin
ZDAP Spring - Left Front
ZGUP Spring - Left Rear
ZSAP Spring - Right Front
ZVUP Spring - Right Rear
Thanks for the Help
Old Jan 5, 2011 | 10:49 AM
thunder98110's Avatar
thunder98110
look at the sticker in the glove box. it will tell you what rear end you have. most likely its limited slip.
Old Jan 5, 2011 | 01:37 PM
wewanaplay's Avatar
wewanaplay
Looks like you do man. this is listed about 1/3 of the way down.
DRBP Corporate 9.25 LD Rear Axle.
I believe the LD means Locking differential. they are in alphabetical order
Old Jan 5, 2011 | 03:03 PM
dodgeramguy85's Avatar
dodgeramguy85
^^^ yeah what he said
Old Jan 5, 2011 | 04:54 PM
Pwall's Avatar
Pwall
i don't think it does i have the same axle and its an open diff
Old Jan 5, 2011 | 05:12 PM
TheePlaymaker's Avatar
TheePlaymaker
I think LD stands for light duty...
Old Jan 5, 2011 | 05:18 PM
dodgeramguy85
I figured it was prob just misspelled or something I have the 8.25 and all it says is Corporate 8.25 Rear Axle
Old Jan 5, 2011 | 06:13 PM
00DakDan's Avatar
00DakDan
Section Moderator
I don't think you do.
It would list it as two lines:
DSAP Anti-Spin Differential Rear Axle
Old Jan 5, 2011 | 09:24 PM
cbassj8's Avatar
cbassj8
I looked in the glove box and it doesnt say anything about a lsd diff. Also I looked at the front differential and it said on a sticker 3.55 Open. So im guessing its not an LSD Diff.
Thanks for all your help
Old Jan 6, 2011 | 09:49 AM
00DakDan's Avatar
00DakDan
Section Moderator
The front would be open, only the rear would be limited slip.
