gear ratios
Old Jan 11, 2011 | 10:42 AM
Dodge Trooper's Avatar
Dodge Trooper
i recently had a 3 inch body lift and 33's put on and noticed it takes allot more rpms to increase my speed so does this meen i need a gear ratio change at all to even out the difference? if so, what gear ratio?
Old Jan 11, 2011 | 12:06 PM
cowboy63645's Avatar
cowboy63645
I would swap to a 3.92 gear front and rear, and if you dont already have a limited slip in the rear, I would add one.
Old Jan 11, 2011 | 12:39 PM
dodgeramguy85's Avatar
dodgeramguy85
You have the 3.9 right? If you do I would move up to 4:10 just because the 3.9 with a stock truck is pretty slow as it is.
Old Jan 12, 2011 | 09:28 PM
Dodge Trooper
what is a limited slip?
and how much would it cost to have a mechanic put in the gears rear and/or front
Old Jan 12, 2011 | 09:35 PM
thunder98110's Avatar
thunder98110
your looking at 400 bucks or so a diff.
Old Jan 12, 2011 | 10:31 PM
dodgeramguy85
Cost is going to depend my mechanic would do it for 100 bucks some might charge 400 just for labor
Old Jan 12, 2011 | 11:37 PM
Hahns5.2's Avatar
Hahns5.2
With 33s I'd go for 4.56s for sure.
