gear ratios
Old Jan 9, 2011 | 06:16 PM
Dodge Trooper's Avatar
Dodge Trooper
Default gear ratios
is a 3:8 gear ratio better than a 4:10? what is the difference between the two?
and if i want to change my ratio to a 4:10 or a 9:25 how would i go about doing so? where can i buy the items for this swap?
Old Jan 9, 2011 | 06:53 PM
thunder98110's Avatar
thunder98110
chrysler diffs came in 8.25 or 9.25 with either 3.55 or 3.92 gear ratio's. a 4.10 would give you getter off the line grunt or better low end for offroading.
Old Jan 9, 2011 | 07:03 PM
Dodge Trooper
so im guesing a 4.10 ratio is good, so where do i buy the items i need for this change? and what items do i need?
Old Jan 9, 2011 | 07:09 PM
thunder98110
do u have a 4x4?
Old Jan 9, 2011 | 07:19 PM
cowboy63645's Avatar
cowboy63645
I would look here http://www.ringpinion.com/ It will give you an idea of prices, parts and also has some calculators so you can figure out what gear ratio is best for you.
Old Jan 9, 2011 | 07:20 PM
Dodge Trooper
yes i have 4x4. i have looked at that site, but i am completely lost with what i need to buy, i see axels and pins and a bunch of stuff but what should i buy to change my ratio to 4.10
Old Jan 9, 2011 | 07:27 PM
cowboy63645
You will need the ring and pinion, and an installation kit, for the front and rear.
Old Jan 9, 2011 | 11:29 PM
dodgeramguy85's Avatar
dodgeramguy85
Really if you do lots of highway You dont need 4:10's they are great for lots of towing,city driving and offroading. I have 3.92's Has great all around power without to much sacrifice of mpg I dont tow to often but my last haul in was 3,400lb and could barely tell anything was behind me. I wouldnt go anywhere else than ringpinion.com I bought gears for my 85 power ram couple years from there and my cousin has bought 3 sets of gears from there they are a great company.
Old Jan 10, 2011 | 12:05 AM
Pete M's Avatar
Pete M
just be aware that you must "set up" gears. they don't just bolt in. this takes some specialty tools and is part science and part voodoo. for comparison, paying a pro to do it can cost 400+ per axle in labor and takes them hours to do.
Old Jan 10, 2011 | 12:10 AM
cowboy63645
I agree, a 3.92 gear is a great all around gear. If your going over a 35" tall tire, then a 4.10, or a 4.56 gear will get you back into the correct power range, but it all depends on your specific needs for your truck.
