4x4 differential
Old Jan 12, 2011 | 05:10 PM
DakMan6704's Avatar
DakMan6704
Remove skid plates...make life easy
I would say keep 2 bolts in...my cover likes to rotate and splash you...sneaky bastad...anyway, its easy...When you put the front on..dry fit a few times to get the motion down so you dont get RTV on your gears...
Old Jan 13, 2011 | 12:09 AM
cycodude's Avatar
cycodude
From: Live: Silverdale, WA; Work: WA, CA, VA, GA, FL; From: WV
OK, got all that. What viscosity gear oil? Can't seem to find this info anywhere...
Old Jan 16, 2011 | 09:48 PM
wlkingdead's Avatar
wlkingdead
i think its 75-90. but i might be wrong.
Old Jan 17, 2011 | 06:40 AM
cowboy63645's Avatar
cowboy63645
75-90 is correct, although I read somewhere that the front takes 75-90 and the rear takes 75-140, so i might be worth calling the dealer and seeing what they say is recommended.
Old Jan 17, 2011 | 10:09 AM
cycodude's Avatar
cycodude
I found it in one of the myriad manuals I have. It's 75W-90. Think I'm gonna use Valvoline SynPower full synthetic.
Old Jan 19, 2011 | 09:05 PM
UWAdventurer's Avatar
UWAdventurer
75W-90 for both the front & rear? I have been thinking about changing mine, 93,000 miles, never changed. Anything special to know? Spray the gears/inside down with cleaner or anything? I know the limited slip needs additive added to the gear oil. I checked on a gasket for the rear, was $4. Trying to decide which gear oil to use, thinking about Mobil 1 synthetic.
Thanks everyone.
Old Jan 19, 2011 | 09:08 PM
thunder98110's Avatar
thunder98110
i used royal purple and its got the additive already in there. and most of us just use red rtv sealant instead of the gasket. loosen the top bolts a few turns but take the bottoms off, and pry the cover with a screwdriver. once its all drained out take out the remaining bolts. 13mm bolts on mine.
Old Jan 19, 2011 | 09:28 PM
dodgeramguy85's Avatar
dodgeramguy85
yep what thunder said and I also just use the red rtv. I've used the rtv for awhile now and with no problems. Oh I also use brake cleaner to clean all the oil slime off the diff and cover.
Old Jan 19, 2011 | 10:02 PM
cycodude's Avatar
cycodude
The Valvoline SynPower has the additive in it also. Can't afford the Royal Purple right now at 4x the cost per quart...
Old Jan 20, 2011 | 10:34 AM
UWAdventurer
So not using a gasket does not cause any clearance problems? Will check out the red RTV. Anyone know the torque spec on the bolts?
Thanks everyone.
