4x4 differential
Old Jan 11, 2011 | 10:10 PM
chief-david's Avatar
chief-david
Default 4x4 differential
@ How many miles should I change the fluid on the 4x4 differential
Old Jan 11, 2011 | 10:13 PM
thunder98110's Avatar
thunder98110
i think its every 30k. tcase uses atf+4 and diffs use any gear oil. i used royal purple.
Old Jan 12, 2011 | 08:19 AM
DakMan6704's Avatar
DakMan6704
I did mine around 30 i think...and just now around 55...but taht was because im an idiot and had the truck in the air.
+1 to Royal Purple...
Old Jan 12, 2011 | 10:28 AM
JustinDD99's Avatar
JustinDD99
i bought mine with 87K a year ago and have 95k on it now and i just did mine and it was brown and chocolate covered...i do some light mudding and stuff so that was part of it...i'd recommend less than 30K if you go through big puddles or a lot of mud. the breather at the top will suck in mud and water
Old Jan 12, 2011 | 11:21 AM
dodgeramguy85's Avatar
dodgeramguy85
I thought it was like 45,000 miles dont know could be wrong the last jeep we had it got changed at 160,000 miles wasnt changed before then lol actually looked alright.
Old Jan 12, 2011 | 02:01 PM
cycodude's Avatar
cycodude
From: Live: Silverdale, WA; Work: WA, CA, VA, GA, FL; From: WV
Guess I should do mine. At 103k + and it hasn't been changed that I know about. Any suggestions/tips as I have never done this before...
Old Jan 12, 2011 | 02:03 PM
thunder98110
rear diff is easy, take the cover off and scrape off the old gasket, and use the red rtv sealant for the new gasket. and fill it back up. 2.2 qts. front is harder with less room to work.
Old Jan 12, 2011 | 03:12 PM
dodgeramguy85
When takin the cover off stick your pan under the diff and take all the bolts out execpt the top one just loosen it about 3 or 4 turns then pry the cover off if you take all the bolts out and try to get the cover off you can make a real mess then scrap all the crap off with a razor blade I like to use brake cleaner to clean all the oil off the cover beware if you have a cut on your hand and brake cleaner gets on it you will be in some pain lol.
Old Jan 12, 2011 | 03:49 PM
cycodude's Avatar
cycodude
Do you do the front one the same way?
Old Jan 12, 2011 | 04:25 PM
dodgeramguy85
Yeah pretty much. Mine was a pita cause of my skid plate.
