Foam in oil filler tube 4.7
Old Jan 13, 2011 | 09:52 PM
jts359's Avatar
jts359
Default Foam in oil filler tube 4.7
Hi For years my 2002 Dakota has had foam build up in the oil fill tube , THE STRANGE part is that it only happens in the winter , I figured the engine was running to cold so i've changed the thermostat several times to no avail, This past Dec I changed the oil to a synthetic and the problem seems to be worse , Any ideas and has anyone else had this problem , Thanks , Ed PS the truck has HD cooling
Old Jan 13, 2011 | 09:55 PM
thunder98110's Avatar
thunder98110
here ya go:
https://dodgeforum.com/forum/2nd-gen...look-good.html
https://dodgeforum.com/forum/3rd-gen...e-oil-cap.html
Old Jan 14, 2011 | 11:01 AM
bpark8824's Avatar
bpark8824
3 thread on this is about 2 weeks, try searching next time.
Don't worry, it's normal you will read in the threads thunder posted...
Old Jan 14, 2011 | 09:38 PM
Derek2002's Avatar
Derek2002
Maybe a moderator should make this a sticky for a little while.
