Brake light stays on - 1997 dakota
Old Feb 19, 2011 | 01:10 PM
  #21
lebaronGTC2011's Avatar
lebaronGTC2011
so i tried to unplug it and light was still on
any other ideas of what it could be.
if you unhook the battery and leave it for a day so it forgets everything then hook it back up. the light it on right away. i think ive checked everything on this truck lol.
i know the dash was pulled out so maybe a gound or wire wasnt put back on? its a long shot but i think i will pull the dash out and see and while im at it i will change the heater core and see why my tempurature doesnt turn all the way to hot(something blocking the blend door)
Old Feb 19, 2011 | 02:12 PM
  #22
00DakDan's Avatar
00DakDan
Section Moderator
Try disconnecting the wire on the e-brake switch.
Old Feb 19, 2011 | 06:52 PM
  #23
lebaronGTC2011
already done and no change... also pulled the switch out and checked to see if it was working like it should and seems to
Old Feb 19, 2011 | 07:48 PM
  #24
00DakDan's Avatar
00DakDan
Section Moderator
You should have Rear Wheel Anti Lock brakes as they were standard in 1997. There is a brake control module, should be on the driver side inner fender. It's not the big setup like the 4 wheel abs unit. Two connectors on it.
There is also a brake pressure switch, it looks like it's on the proportioning valve, it has a black 2 pin electrical connector.
A DRB can scan the system. The red warning light can go on if there is a fault. If the controller has failed it will need to be programmed for the truck. It might be easier to check it before you pull the dash.
