how to identify gears
Old Jan 19, 2011 | 02:40 PM
energumeno's Avatar
energumeno
Default how to identify gears
I bought my dak two years ago an am thinking in installing 35s an probably change the gears on both differentials.
I don't know what did the previous owner did to the truck so, is there any way of knowing which type of gears (3.55?) is my truck using?
Old Jan 19, 2011 | 02:43 PM
thunder98110's Avatar
thunder98110
sticker in the glove box.
Old Jan 19, 2011 | 05:10 PM
dodgeramguy85's Avatar
dodgeramguy85
Yeah the glove box will tell you everything you need to know. You have to change front a rear gears if you plan to use 4x4 at all.
Old Jan 19, 2011 | 07:12 PM
Pwall's Avatar
Pwall
glove box, build sheet sticker, on the axle or take the cover off the diff and count the teeth on the ring gear it should also be stamped on the ring gear
Old Jan 19, 2011 | 10:32 PM
Pete M's Avatar
Pete M
or you can jack up one rear tire (if no posi), put the trans or t-case into neutral, and rotate that tire around twice while counting the rotations of the driveshaft.
If the rear axle has posi, then you need to jack up both tires, put it into neutral, then rotate the tire around once while counting the rotations of the driveshaft.
for example, if you had 4.10 gears then the driveshaft would rotate around just over 4 times. 3.55 gears would be 3 and a half times.
Old Jan 21, 2011 | 10:46 PM
energumeno's Avatar
energumeno
Thanks!!! Just did this and confirmed they are 3.55, just wanted to confirm because de PO did a lot of mods on the truck and i didn't know if he had changed the gears.
BTW i will be installing 35s on the truck. Do you think that it will do ok mated with 4.10 gears?
Old Jan 21, 2011 | 10:50 PM
thunder98110
yeah 4.10 will be good.
Old Jan 21, 2011 | 10:52 PM
Hahns5.2's Avatar
Hahns5.2
You want 4.56 gears with 35s.
Old Jan 21, 2011 | 10:58 PM
thunder98110
haha really? i figured 410 would be good enough. nevermind dont listen to me, haha.
Old Jan 21, 2011 | 11:04 PM
dodgeramguy85
4.56 with big 35's are good. You could do 4.10s but it will prob be a bit sluggish
