where can I find some more Hp?
Old Jan 26, 2011 | 12:07 AM
fourpointseven's Avatar
fourpointseven
Default where can I find some more Hp?
Well, Without splitting the motor Is there anyother way I can crank out a bit more juice?
I'm already running a programmer from superchips, KN CAI, and looking into a TB from fastman. I already got a Exhaust, im running stock manifolds with duel glasspacks(true duel).
Is there anything else I can throw at this motor just to up it up a little? im not looking to spend thousands. Just curious As I have my ideal truck.
Old Jan 26, 2011 | 12:09 AM
Blaze10's Avatar
Blaze10
a cam.....
Old Jan 26, 2011 | 12:11 AM
thunder98110's Avatar
thunder98110
sct tuner. and high flow cat, efan.
Old Jan 26, 2011 | 12:12 AM
thunder98110
you can regrind a non ho cam for like 300 bucks. i have mine i will give you. if you are interested.
Old Jan 26, 2011 | 12:20 AM
thunder98110
you can actually get it ground to a 206ish. crane cams does it. or the did it in the past. w/o a tune ho and 206 cams are pretty much the same. but with a tune 206 will exceed the ho's. but dont get me wrong, i absolutely love my ho cam with sct tune.
Old Jan 26, 2011 | 12:21 AM
fourpointseven
Thunder, I just was just watching Your videos After the installation of your cams... It sounds By the way of your voice It improved Your engine Quite Well, Really well.. lol What do you mean, You have another one? Is their any tuning to cams or just drop and giver hell. I havn't really researched Cams, I'm slowly starting to read more and more about the guts of my engine.. That big of a boost eh?
Old Jan 26, 2011 | 12:23 AM
thunder98110
our cams are plug and play, no break in period. i drive a few blocks and then romped on her. i have a stock 4.7 cam. but like i said it can be re ground. ill give too you if you want to go the cam route. just pay shipping.
Old Jan 26, 2011 | 12:26 AM
fourpointseven
Thunder, check your inbox. If my address dont work, Try .ca
Old Jan 26, 2011 | 03:01 PM
thunder98110
apparently standard 47 cam has a different centerline than a true ho cam. so you wont get the full benefits.
but crane cams does still regrind cams for $289 (called them this morning)
