"Kegger" intake question
Old Feb 17, 2011 | 06:52 PM
bigreed91's Avatar
bigreed91
Default "Kegger" intake question
Rather than getting a new intake this summer i figured id ask if the kegger intake manifold on my 5.9 can be modded in any way to improve it?
Old Feb 17, 2011 | 07:19 PM
bigreed91's Avatar
bigreed91
sorry i should of done more research before posting. found out you can but im not sure if its really worth it, one guy had before and after dyno runs and only showed a gain of 8hp and loss of 10ft-tq, though said it did help the mid to high range.i might would consider buyin a used one and trying it but so far im not likeing the results. has anyone here done it?
Old Feb 17, 2011 | 09:26 PM
jondakotaguy's Avatar
jondakotaguy
Yeah.. typically if you do not go behind such a mod that is allowing that much more air to come through, if you do not go in and tune the system exact it will cause you to loose torque or low end 'umph' but have gains in the mid to upper RPM bands..
Thats why I made the post "wheres the proof Mods! post.. in the hopes some one that has done some of these mods would post some results..
Old Feb 17, 2011 | 09:52 PM
bigreed91's Avatar
bigreed91
yeah i feel ya, id like to see some before and after dyno runs on cams
Old Feb 17, 2011 | 09:55 PM
thunder98110's Avatar
thunder98110
clean looking rt. there is a diy kegger mod on here.
Old Feb 17, 2011 | 10:45 PM
bigreed91's Avatar
bigreed91
ill search around and try to find it
Old Feb 17, 2011 | 11:31 PM
jondakotaguy
This
https://dodgeforum.com/forum/2nd-gen...od-diy-16.html
Old Feb 18, 2011 | 05:15 PM
bigreed91's Avatar
bigreed91
Thats a good thread, i think i might look around for a newer one that didnt come with the divider and just cut the runners also if i do this i guess ill go ahead and get the hughes kit to fix the belly pan
Old Feb 18, 2011 | 05:17 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The divider brakes off very easy. But having an extra one to do on the side will help. Just swap the intakes. Eliminates down time.
Old Feb 18, 2011 | 05:20 PM
bigreed91's Avatar
bigreed91
yeah id definetly have to have an extra cause my truck is my only way to go
