AC compressor swap
Why are you changing the compressor? Has the system been opened to the air? It wouldn't hurt to replace the orifice tube.
You will need to add oil.
For the compressor, measure what comes out of the old and put the same amount into the new compressor. For the accumulator, 3 ounces. This is all from the 2000 FSM. Make sure you use oil compatible with r134a.
