Power Steering/steering.
Old Mar 3, 2011 | 04:29 PM
farscaper's Avatar
farscaper
Exclamation Power Steering/steering.
Hello ladies and gent's.
I have a 97 dodge dakota v8 5.2lt. My issue is with my steering.
Ive notice when i slow down from a speed of 25-35mph to make a turn, my steering becomes hard. And from after going reverse for a few feet , to putting it in drive lets say to turn the wheel left or right from a stop position it gets hard to turn. I would have to step on the gas a little for it to loosen up and let me turn with out the stiffness of the steering wheel. I haven't notice any leeks from the power steering pump, the fluid levels is at nominal levels. But the truck drives fine though, its only from what i mentioned above. Any help would be appreciated guys.
Old Mar 3, 2011 | 05:35 PM
jondakotaguy's Avatar
jondakotaguy
Sounds like it's getting in a bind.. Check your fluid? Change your fluid? Make sure the lines are clogged?
Old Mar 3, 2011 | 08:26 PM
00DakDan's Avatar
00DakDan
Section Moderator
Is it doing it when you use your brakes to slow down, or stop then go forward? Do you have a sticking caliper?
