Help!? Headbolts
Old Mar 6, 2011 | 03:47 PM
00daksport25's Avatar
00daksport25
Default Help!? Headbolts
I'm replacing the head gasket on my 2.5 and I am having a hell of a time getting the head bolts off. I sprayed some pb on it let it soak a bit and still I can't get them off. I'm using a breaker bar and it feels like I'm going to break them off. Any tips?
Thanks.
Old Mar 6, 2011 | 06:42 PM
00DakDan's Avatar
00DakDan
Section Moderator
They are going to be tight. They were put in at 110 ft lbs, 100 for #11.
You are using 1/2" drive tools? Get a bigger bar.
Old Mar 6, 2011 | 07:58 PM
Blown287's Avatar
Blown287
They will be tough. I've pulled the heads off 3 different 4.7Ls and it's never easy breaking the head bolts loose.
Old Mar 7, 2011 | 11:06 AM
00daksport25
I finally broke them loose last night and got the head off. The gasket blew between cylinder 1 and 2. I'm sending the head to a machine shop to get it checked for warping, cracks and to get it resurfaced.
Old Mar 7, 2011 | 11:14 AM
00DakDan's Avatar
00DakDan
Section Moderator
Thats a common problem on the 2.5 (and 2.2). Make sure you get all the air out of the cooling system when you get it back together and spend some money on a good quality head gasket.
Felpro makes one for the turbo version that will fit.
