Bad U-Joint Symptoms and DIY Repair
Old Mar 20, 2011 | 05:30 PM
qcdakota5sp's Avatar
qcdakota5sp
Default Bad U-Joint Symptoms and DIY Repair
Hey all,
I recently found a thread that was indicating a squeaking noise I was having was related to the U-Joint
( https://dodgeforum.com/forum/2nd-gen...ml#post2443314 )
Yesterday when I drove to work I didn't hear the tell-tale squeak and in its place I'm having vibration when I accelerate. If I accelerate at the same speed that a semi would I dont' have it but anything mor than that and I feel it. It almost feels as if the truck is working harder than it should.
Anyways - do you guys think this is officially my U-Joint?
If so any pointers on a fix - I'll be doing it myself? I'm planning on taking care of this next weekend, do you think I can make it until then without a catastrophic failure if I go really easy?
Thanks!
~D
Old Mar 20, 2011 | 05:33 PM
frydaddy82's Avatar
frydaddy82
have you jacked it up or got under there and looked? if its a bad vibration then i would be worried cuz a broke ujoint at 60 sucks!
Old Mar 20, 2011 | 06:50 PM
qcdakota5sp
Well I put it in neutral and climbed underneath and tried moving the drive shaft around. Barely any play in the the rear-end and couldn't notice any in the u-joint.
Would I be able to tell if the u-joint was bad by this?
Old Mar 20, 2011 | 07:04 PM
Lebbie54's Avatar
Lebbie54
Well U joints all squeel when they are going bad. So if it never has or it stopped it is probably something else. When mine when out once it started it never stopped. I heard it till it was replaced. Trust me you will know when it is a you joint, it sounds like someone is chocking a gerbil when you are driving.
Old Mar 20, 2011 | 10:27 PM
jondakotaguy's Avatar
jondakotaguy
I'm not sure of squieling sound.. but I know when a U-Joint starts going out/bad.. they go dong.. thunk.. how ever you want to describe it.. when you put in gear.. more profoundly as you change gears.. with foot on brake.. Driver to R.. changing either way.. sometimes when you are slowing down real quick from an acceleration.. and it down shifts as you slow you might here it too..
You would also feel it..
Old Mar 21, 2011 | 12:10 PM
qcdakota5sp
It was squealing very badly (chocking squirrel/gerbil) not more than three days ago but it up-and-up stopped... I'm concerned about losing it so I made an appointment for tomorrow to have it re-done. I was going to do it myself but we're due for 15cm today so I'm not interested in crawling around in that crap to deal with it.
Bring on the summer!
Old Mar 22, 2011 | 04:54 PM
qcdakota5sp
Ah
I took it into the local dealer today and it was in fact the u-joint. One of caps had lost all of the lubrication and the bearings were toasted.
But turns out the original owner put a 7year 160000 power-train warranty on my truck so they replaced for free - most excellent.
