Please Help Before I Take It To The Shop
Old Mar 21, 2011 | 07:17 PM
sonderegger's Avatar
sonderegger
Default Please Help Before I Take It To The Shop
my truck seems to have no overdrive after i drive it for about 5 minutes. for the first time i start it up for the day it'll shift into 4th (O/D) just fine and lock the TC. but after i drive for about 5 mins it'll kick back into third and will not go back into forth for the rest of the day unless i let the truck sit for like 6 hours at least (then itll go into O/D and kick back out after 5 mins). ive replaced the ECT sensor and the fluid and filter (with ATF+4). someone else has got to have had this problem. im so sick of trying things and spending unnecessary money so i'm probably gonna take it to my local tranny shop and have to spend quite a bit.
thanks
truck: 1999 dodge dakota 4x4 5.2L Sport Club Cab
Transmission: 44RE
Old Mar 21, 2011 | 07:41 PM
Senate427's Avatar
Senate427
thanks
Transmission: 44RE
I'm thinking speed sensor or O/D solenoid. When my overdrive kept going on and off I found a broken speed sensor wire and bad sensor.
Old Mar 21, 2011 | 07:52 PM
sonderegger
the thing is that its really consistant like its the exact same everytime itll have the over drive then 5 mins later itll drop out
Old Mar 21, 2011 | 11:01 PM
McNasy's Avatar
McNasy
is it out of o/d or is the tc not locked? what does the rpm jump up to when at freeway speed? can you even drive on the freeway when it does it?
Old Mar 22, 2011 | 01:28 PM
sonderegger
at 100 kph (60 mph) im doing like 2500 RPMs the torque converter locks just fine cuz if i press the od off button itll lock the TC in 3rd and wen the OD does work itll lock the TC in 4th at 80 kph
Old Mar 23, 2011 | 01:33 AM
sonderegger
anyone else?
Old Mar 23, 2011 | 08:56 AM
dodgeramguy85's Avatar
dodgeramguy85
Im betting its the od shift solenoid. Weird cause im getting the shift solenoid done in the jeep(42re) on thurs, pulling out in 3rd all the time is kinda hard on the tranny lol
Old Mar 23, 2011 | 10:20 AM
hanleysh's Avatar
hanleysh
Could be your transmission getting hot of it's that consistent, if our trans get to warm or even if they don't get warm enough they'll drop o/d
Old Mar 23, 2011 | 12:31 PM
sonderegger
yea its kind of a **** off and it just eats the gas. i get 400 km to a tank with no overdrive and its $20 per 100 kms
Old Mar 23, 2011 | 01:27 PM
Senate427's Avatar
Senate427
If a speed sensor is faulty the transmission will rely on the temp sensors to shift. Just something I experienced in the winter.
sonderegger did you check your PCM for codes?
