Push Start
Old Mar 22, 2011 | 08:16 PM
01KotaQuad's Avatar
01KotaQuad
Default Push Start
what's the best way to go to get push start? any ideas? i'm gonna add it soon just for the hell of it and was curious how i should wire it. i want it like this...
http://www.youtube.com/watch?v=s2oUQgOlR0U
Old Mar 22, 2011 | 09:21 PM
dodgeramguy85's Avatar
dodgeramguy85
You need to get a wiring diragram then figure out which wires get power when the key is in the start position. I want a true push start test drove a 2011 grand cherokee and love the fact that you dont even need to take your keys out of your pocket
Old Mar 22, 2011 | 11:59 PM
moe7404's Avatar
moe7404
Default push start
any chrysler auto trans after 1965 will NOT push start. unless they put a oil pump on the output shaft since then.
Old Mar 23, 2011 | 10:49 AM
DakMan6704's Avatar
DakMan6704
Moe...he is talking push-button starting...(I was confused about wiring a truck down the road at first glance...ha!)
Easy to do, pending if you want to do RF key fob, or if you want to just turn your key, then be able to push a button. The latter is easy, just need a diag like stated.
Old Mar 23, 2011 | 01:28 PM
01KotaQuad's Avatar
01KotaQuad
haha yeah not push start...push button. i'm wanting to pop the ignition out and hide it underdash with the key. i'm gonna use a pop out filler to plug the hole that the ignition was in, and pop the push button in the cig lighter hole in the one that's in the dash, so all i'll do is get in, push the cig lighter tray so it drops down...turn key and push the button... if i can get that bluetooth key that would be friggin awesome...my girls hynudai has that and i love that.
Old Mar 23, 2011 | 02:26 PM
McNasy's Avatar
McNasy
i have mine set up so you can hop in and use the key(for the wife) or for me, i flip 2 switches and push the button and away i go. you must disable the steering lock to use it without the key.
Old Mar 23, 2011 | 03:14 PM
01KotaQuad's Avatar
01KotaQuad
And how do u disable the steering lock?
Old Mar 23, 2011 | 03:48 PM
McNasy's Avatar
McNasy
ill see if i have pics, but you need to pull the wheel off and remove the "dog", the piece that locks the shaft in place when the tummbler is not turned. ill look to see if i took pics. once its out you will no longer have a steering lock, just a fyi.
Old Mar 23, 2011 | 05:52 PM
DakMan6704's Avatar
DakMan6704
That too...but ummm, is your truck Auto? cause that makes it one or two wires easier too...I only say that cause mine is 5spd...
Old Mar 23, 2011 | 07:23 PM
01KotaQuad's Avatar
01KotaQuad
Yeah mines auto...
