Tune Up time need some advice
Old Apr 6, 2011 | 09:04 PM
Muddking's Avatar
Muddking
Default Tune Up time need some advice
Time to change Oil, Tranny, front and rear diff, plugs and other odds and ends.
'00 QC with a 4.7L, 9.25 rear diff. 125k miles. Nothing but mobile 1 syn. since i bought it in '03
What do you run for Plugs?
Tranny fluid?
Front and rear gear oil?
Transfer case?
Any other stuff I should change while I'm at it, i usually let my local dealer do the service but i want to give it a try.
Old Apr 6, 2011 | 09:09 PM
thunder98110's Avatar
thunder98110
tranny fluid= mopar atf+4
diff oil= i used royal purple
tcase= same as tranny
plugs=autolite or ngk usually respond well to the 4.7
Old Apr 6, 2011 | 09:40 PM
Pwall's Avatar
Pwall
don't forget friction modifier if you have a limited slip and since you use mobile 1 i would also use it in the rear i believe its 175w40
you might want to do coolant, pwr steering, brake fluid, and grease points and don't forget to grease the front drive shaft
Old Apr 6, 2011 | 10:17 PM
bigreed91's Avatar
bigreed91
Its not really part of a tune up but while your under the front id check the ball joints, bushings, etc.
Old Apr 8, 2011 | 04:57 PM
Muddking's Avatar
Muddking
Both my lower ball joints are grease able and get some every oil change.
NGK it is.
Mobile 1 are ready has the modifier in it doesn't it. Grease the front shaft, coolant, pwr steering, brake fluid?
I should change or check pwr fluid, coolant,brake fluid.
Thanks for the input guy
Old Apr 8, 2011 | 05:25 PM
Pwall's Avatar
Pwall
yes if the fluids have never been changed the need to because the fluid breaks down and gets dirty and can start breaking down seals and in the case of the brake fluid water builds up and can rust the brake lines and the coolant can start corroding the engine block
Old Apr 8, 2011 | 08:17 PM
bpark8824's Avatar
bpark8824
Go to wally world and get the autolites the book calls for. I forget what the number is, but they have them. They're cheap and work just as good if not better than any other plug. No need to buy NGKs.
Old Apr 9, 2011 | 01:47 AM
Blaze10's Avatar
Blaze10
i am assuming he already bought NGKs
Old Apr 9, 2011 | 08:30 AM
Muddking's Avatar
Muddking
Haven't yet, that's part of my mission today. I have had great luck with NGK's in my sleds and bikes.
Regular Autolites or Platinum, Iridium?
Old Apr 9, 2011 | 11:20 AM
thunder98110
i had double platinum autolites but they dont do anything over the basic ones other than last longer.
