4bt Swap
#61
Patrick
#62
#63
Axle shafts...
I struggled with whether to fight to get the pan to seal but finally just decided a solid axle swap was a better route so I broke the axle at the outer joint and put the outer axle shaft back through the hub and tightened it up. For now I still have the joint hardware in the shaft and was just going to use a 3 1/2 inch rubber cap made for use on PVC pipe to seal it up with some band clamps on the outside but after thinking it through further I'll probable just pull the joint hardware (race and the joint bearings) out and leave the inside open.
Patrick
Patrick
#64
#65
And it's on the road! First test drive tonight (further than around my circle) was a success! Motor runs in the zone for great fuel economy at between 60 and 65mph. Looking forward to getting some miles on it and I'll report back with the stats. Now on to an exhaust system - just a basic 3" to a resonator to 4" out the back then I'll tidy up the interior a little.
It's been fun!
Patrick
For the record, a Cummins Ram 4" exhaust works well - I have an hx30 with a 2.5 exhaust housing - jumped that to 4" shortly after the downturn then used flex to make the lower turn to the back then the Ram 4" all the way back. I inserted the resonator as well - might opt to run without it at some point but it's not hurting for now.
It's been fun!
Patrick
#66
Update
Only around 1800 miles on it since the swap and one transfer case repair - they eat the aluminum parts without oil... Replaced that range fork and a new set of seals and it's doing great. I also sealed up the front shaft exit on the case to eliminate it as a leak point. Considered swapping parts to a 2wd nv4500 setup but this route was much easier and less expensive. It definitely is a different truck than with the v6!! I'm at around 24-ish mpg with it but haven't had a chance to do anything to try to improve that. I'm in the process of getting gauges - bought a 3-gauge pillar pod for boost, pyro, and one yet tbd.
I'll get some pictures up when I take a few...
#68
#69
It's pretty funny - you can really tell the people who know and/or like trucks - they look up when they hear it coming and look away and then do a double-take and either stare or point... I've had more than a few come up and want to take a look at it when I park it somewhere and have had a couple ask me my price! All in all it's been a fun experiment and one I'm glad I started.
#70
