manual locking hubs
Old Apr 21, 2011 | 11:02 PM
ryan_brown33's Avatar
ryan_brown33
Default manual locking hubs
is it possible to put manual locking hubs on the 2nd gen daks? i got a 2002 qc 4.7 awd. does anybody even make manual hubs for these trucks? i figure if you could unlock the hubs and keep the front drivetrain from, you could save a couple mpg's and decrease the wear on the front end. will it do anything for the AWD? thanks
Old Apr 21, 2011 | 11:10 PM
ryan_brown33
by the way sorry if this has been brought up before in previous threads
Old Apr 22, 2011 | 12:11 AM
Crazy4x4RT's Avatar
Crazy4x4RT
No you can not. By factory it should have a CAD (Central Axle Disconnect) which does the same thing, it disconnects 1 axle shaft so the entire axle doesn't move.
Old Apr 22, 2011 | 12:28 AM
ryan_brown33
im assuming the CAD you mention would be in the transfer case?
Old Apr 22, 2011 | 12:34 AM
Dakkkota's Avatar
Dakkkota
CAD??? 3rd gen to?
Old Apr 22, 2011 | 12:36 AM
ryan_brown33
are you AWD?
Old Apr 22, 2011 | 01:15 AM
Crazy4x4RT's Avatar
Crazy4x4RT
No like I said it disconnects an axle shaft, so it would have to be on the front differential to disconnect the axle shaft. I'm not sure on all the changes of the years if they did away with it or not.
Old Apr 22, 2011 | 01:18 AM
ryan_brown33
o ok makes sense
Old Apr 22, 2011 | 07:57 AM
loafer's Avatar
loafer
I have a 2000 QC and there is no axle disconnect. I wonder what years they started using them?
Old Apr 22, 2011 | 10:19 AM
Crazy4x4RT's Avatar
Crazy4x4RT
I know for sure 87-93 had them. I believe 97-99 may have, then in 2000 it may have changed. Not 100% on it. But most modern 4wd have them.
